March 12, 20197 yr I am looking for a replacement for my Insteon hub. My setup does not use Zwave. From the looks of the ISY it does work with my Amazon Echo devices. Any help/ direction would be appreciated. TIA.
March 12, 20197 yr I use the ISY for my Insteon set up and also have an Alexa for voice control. there is a little bit of a learning curve for the ISY, and you’ll need to factory reset and install all of you Insteon devices to the isy. Doing that a little at a time; room by room, function by function works best, youll need the ISY994i pro, a 2413s Insteon plm and the ISY portal service: https://www.universal-devices.com/shop/, Paul Edited March 12, 20197 yr by paulbates
April 9, 20196 yr 4 hours ago, peknogutre said: Hi Paulbares, does it really nessecary to make the upgrade, as Insteon Hub for me is getting the Job done after tries. If the hub works for you, I see no reason to make the upgrade.
April 11, 20196 yr Author the hub does work just fine, however, it does have some limitations. If I hadn’t ever used HomeSeer or the JDS Timecommander before that I could be happy with it.
April 11, 20196 yr 34 minutes ago, Theinspector said: the hub does work just fine, however, it does have some limitations. If I hadn’t ever used HomeSeer or the JDS Timecommander before that I could be happy with it. It sounds like you are wanting to break into some new challenges. For me, ISY was just what the doctor ordered and AFAIC here isn't anything ISY can't do. The only limiting factor with ISY is my imagination.
