AT&T to end email-to-text ×
Ideas for tidy sprinkler valve wiring
carealtor
I just replaced all my sprinkler valves (13 of them) and am wiring them up now.  It seems like such a rat's nest of wires out there in the open for everyone to see.
Anyone been able to come up with a way to tidy this up?  What have you done?
Here's an example for the rainmachine HD which can be difficult to integrate, especially with more than one 13 wire bundle
Paul
Ok, wasn't sure which one you meant. My system has 2 irrigation work boxes that mount under ground, with a lid at the surface. It's filled with a small gravel field so no standing water.  You could do the wiring there. Run each relay's wiring vertically to the ground along the stand pipe, and then underground to the box which should be in the middle of them. This part of this video shows what I mean.
24vac connections can potentially make a spark.. Not sure if you would have dry leaves, but those connections should not be out in the open
Paul
