Recommendations need replacement of Insteon 2477SA
leonpc
It seems like SmartHome  in their infinite wisdom have decided to stop the manufacturing of the 2477SA 220V / 240V 30 AMP INSTEON Load Controller (Dual-Band).  I wanted to use it to switch the power to the hot tub pump.  Any recommendations for replacements...
I am looking at these:
https://www.amazon.com/Aeon-Labs-White-V3-26-AL001/dp/B00MBIRF5W
https://www.amazon.com/GE-Appliance-Required-Works-SmartThings-14285/dp/B00YTCZZF0/
https://www.amazon.com/dp/B00WXLRF2U/
TIA
If you have an existing Zwave network Aeotec Zwave devices have worked well for me and their firmware is field upgradable. They have excellent technical support.
You need to make sure that their switch is compatible with the ISY firmware version you're running.  I'd check with UDI before purchasing.
  • 1 year later...
4 hours ago, SamOpp said:
I am having the same problem. what did you use as an alternate solution? Thanks
Do you have a Z-Wave enabled ISY904i? The modules in the older post are Z-Wave devices.
You could use a ELK9200 heavy duty 220 Volts contactor in its  enclosure. https://www.elkproducts.com/product-catalog/elk-9200-heavy-duty-relay-contactor Controlled by a 120Volt Insteon plug in module or a switch.  Or a contactor controlled by an Insteon Module.
You can buy a 2 pole Contactor rated for the load with 120V control voltage. Use a standard Insteon on/off switch to control the turning on/off of the Contactor.
  • 2 months later...
Midrar, do you have an example of what you're talking about - a 2-pole contactor rated for a 240v/30-amp circuit, with a 120v control?
They are easy to find type "2 pole 30 amp contactor 120 volt coil" into amazon search (be wary of amazon search, it tends to mix in others that don't exactly match, double check your choice for all values including coil voltage).   Be aware that some are noisy, some are quieter than others.  I prefer to stick with name brands like siemens, Eaton, Square D, etc.  You'll also need a proper enclosure, if it's metal be certain to follow proper grounding protocols.
  • 3 months later...
      38k
      379.1k
