After update, I can't sign in
After a firmware update, I can't sign back in using my past user and password.  What is the default?
When this happens, typically the credentials revert to admin / admin. Then change back to what you want
Paul
Edited by paulbates
The most current version of the 5.x branch is 5.0.15a, located here. That is the only version to consider at this point.
To address where you are right now, my recommendation is to
Paul
Edited by paulbates
But it says in order to update to some of those I had to have these other ones installed first.  Am I reading that wrong?
Is there something special I need to do?  Or is it just manually?  It has been so long since I have updated, I've forgotten. :)
That worked.  Now, how do I get it to launch directly like I had it before?  I'll keep looking.  I like it in my taskbar to just click on and go.
