ISY99 Question
Hi - Thinking of upgrading Insteon network control with an ISY-99. Wanted to know if the unit supports and can set links up in a an IR-Linc as well as an EZ-Rain controller since I currently use these extensively.
Thanks for your help!
Hi pacificsloop,
Thanks so very much for your interest.
IRLinc - yes
IRLinc Transmitter - no
EZRain - depends on your EZRain's firmware. The latest usually works.
Please note that ISY cannot program EZRain timers nor can it call them.
Thanks Michael -
Couple of more clarifications.
1) Are there enhancements in queue to set the Ezrain timers?
2) Can the ISY turn an EZRain Zone on manually?
3) Can you use ISY it to assign the Ezrain programs/zones/inhibit functions to keypadLinc buttons?
4) Can you use the ISY to assign IRLink stored commands to keypadLink buttons?
Thank you again for your help!
Hello pacificsloop,
My pleasure and apologies for a tardy reply.
1) We do have this a requirement to support EZRain timers; the priority is low
2) Yes, ISY can turn on/off each zone
3) You can only use ISY to link zones to other ISNTEON devices (not programs and inhibit functions)
4) Yes, you can link IR link groups to INSTEON devices including KPL buttons
Thanks Michael -
