Scene Problem with KeyPadLinc
I have a Scene defined in ISY99 for my living room/entry lights...there are approx 10 devices (various LampLinc's and SwitchLincs and InLineLincs) in the scene. One of these devices is the direct load of a KeypadLinc (pushing the KeypadLinc top/bottom controls it).
Using ISY, I have linked up Button A of the same KeypadLinc to control the living room light scene. All works fine EXCEPT it will not control the direct load of the same Keypadlinc.
I have another controller for the same scene, a RemoteLinc...and it has no problem controlling everything, including the direct load on the keypadlinc.
Any idea what is causing this behavior and how I can fix it?
Hello pdxcav,
Apologies for the inconvenience.
Two questions:
1. What firmware version is your ISY
2. Have you checked the on level for the load for that button? i.e. click on that button within the scene and then check the on level for the load to your right
Thanks Michel for the quick response!
ISY Firmware is: 2.7.4
The on level for the load is 100.
As I mentioned in the original post, the RemoteLinc works just fine (i.e. controls the load) with the scene...it's just when I use Button A of the KeypadLinc (it doesn't control the load).
pdxcav, older KPLs do not allow you to set the level using a secondary button, they only use the local level/rate. How old is your KPL?
Rand
My KPL is brand new. Also, I'm not interested in setting the level. I only want it on.
