How to run program based on status of Hue bulbs?
Running polyglot v2 with the Hue nodeserver and in the AC I can see the status of the bulbs.
I have two lamps on my headboard and a 6 button KPL in my bedroom where one of the buttons toggles a scene.
I'm trying to turn off that scene (MasterHeadboardLights) when the bulbs are (both) off.
I made a program that says:
MasterHeadboardSceneOff - [ID 002A][Parent 0001]
        'Hue Bridge / Left Light' Status is 0.0000%
    And 'Hue Bridge / Right Light' Status is 0.0000%
        Set 'Upstairs / MasterHeadboardLights' Off
But it doesn't work.
What am I missing?
I can use my phone to turn the scene on and off and see the KPL key light up and go dark.
Running 5.0.14.
Any thoughts?
What am I missing?
Running 5.0.14.
Any thoughts?
I have none now but...
Can you use "switched" instead?
Can you use "Off"?
Can you use < 1% ? Why so many decimal places? I suspect ISY is showing you a rounded off value and never really matched 0.0000%
BTW: Your AND specifies you must have both off. This will not work with "Switched" triggering. Two devices are never triggered at the same time with ISY logic.
Well I feel silly. I looked at polyglot and it said connected, but it wasn't. I restarted it and the program worked.
I tried a couple different things and I stopped on less than 1% when I thought of restarting polyglot, but I think my original program would work.
Just FYI the decimal places were the only option.... I didn't add them all.
Thanks for the reply.
Edited by danbutter
