May 23, 20197 yr When I started up the launcher, I received an error message, Socket open failed Java.net Connect exception: Connection failed. After that message i lost my icon on the dest top. I deleted java and reinstalled same. Still nothing. Also I get one blue light in isy flashing slowly. Im operating on a Mac, Mojave ver. 10.14.5 Thanks for your help, Steve
May 23, 20197 yr 4 minutes ago, sl1509 said: When I started up the launcher, I received an error message, Socket open failed Java.net Connect exception: Connection failed. After that message i lost my icon on the dest top. I deleted java and reinstalled same. Still nothing. Also I get one blue light in isy flashing slowly. Im operating on a Mac, Mojave ver. 10.14.5 Thanks for your help, Steve The launcher/java combo works fine on Mojave (as in, "It works for me"). You might have an ISY problem however, as indicated by the blinking light. See the Wiki link below: https://wiki.universal-devices.com/index.php?title=Main_Page#Front_Panel_LEDs.2FLights
May 23, 20197 yr Author I went to the site you gave me. I reset isy to factory defaults. The blue light that blinking is the memory light. I do not have mini sd card installed. The same message still comes as I wrote above. I did to change any setting on my network, isy has beed running for about 3 weeks with no errors or problems.Any other thoughts ? Thanks for your help, Steve
