Switching from DSClink to nodelink
Yes.  Or just enter the first 6 characters in NodeLink.
DSCLink used to just take the first 6 characters and send (that's all the EVL3 cared about).
NodeLink supports the EVL4 as well so it will try to send the full 9 (and fail).
io_guy
Thank you very much for your time and expertise, much appreciated. Everything seems to be working now.
  • 1 month later...
I needed to go into the logs on the isy for something else and noticed these entries in the log. There are literally thousands of them. Is this normal. sample below
DSC Alarm Custom Control 11 -1 Thu 2019/07/11 05:15:25 PM System Log
RainMachine Custom Control 1 -1 Thu 2019/07/11 05:15:33 PM System Log
DSC Alarm Custom Control 11 1 Thu 2019/07/11 05:15:55 PM System Log
RainMachine Custom Control 1 1 Thu 2019/07/11 05:16:04 PM System Log
DSC Alarm Custom Control 11 -1 Thu 2019/07/11 05:16:25 PM System Log
RainMachine Custom Control 1 -1 Thu 2019/07/11 05:16:34 PM System Log
DSC Alarm Custom Control 11 1 Thu 2019/07/11 05:16:56 PM System Log
RainMachine Custom Control 1 1 Thu 2019/07/11 05:17:04 PM System Log
DSC Alarm Custom Control 11 -1 Thu 2019/07/11 05:17:25 PM System Log
RainMachine Custom Control 1 -1 Thu 2019/07/11 05:17:35 PM System Log
DSC Alarm Custom Control 11 1 Thu 2019/07/11 05:17:55 PM System Log
RainMachine Custom Control 1 1 Thu 2019/07/11 05:18:05 PM System Log
DSC Alarm Custom Control 11 -1 Thu 2019/07/11 05:18:25 PM System Log
RainMachine Custom Control 1 -1 Thu 2019/07/11 05:18:35 PM System Log
DSC Alarm Custom Control 11 1 Thu 2019/07/11 05:18:56 PM System Log
RainMachine Custom Control 1 1 Thu 2019/07/11 05:19:06 PM System Log
DSC Alarm Custom Control 11 -1 Thu 2019/07/11 05:19:25 PM System Log
RainMachine Custom Control 1 -1 Thu 2019/07/11 05:19:36 PM System Log
DSC Alarm Custom Control 11 1 Thu 2019/07/11 05:19:55 PM System Log
RainMachine Custom Control 1 1 Thu 2019/07/11 05:20:06 PM System Log
DSC Alarm Custom Control 11 -1 Thu 2019/07/11 05:20:25 PM System Log
RainMachine Custom Control 1 -1 Thu 2019/07/11 05:20:37 PM System Log
DSC Alarm Custom Control 11 1 Thu 2019/07/11 05:20:55 PM System Log
RainMachine Custom Control 1 1 Thu 2019/07/11 05:21:07 PM System Log
DSC Alarm Custom Control 11 -1 Thu 2019/07/11 05:21:25 PM System Log
RainMachine Custom Control 1 -1 Thu 2019/07/11 05:21:38 PM System Log
DSC Alarm Custom Control 11 1 Thu 2019/07/11 05:21:55 PM System Log
RainMachine Custom Control 1 1 Thu 2019/07/11 05:22:08 PM System Log
DSC Alarm Custom Control 11 -1 Thu 2019/07/11 05:22:25 PM System Log
RainMachine Custom Control 1 -1 Thu 2019/07/11 05:22:38 PM System Log
DSC Alarm Custom Control 11 1 Thu 2019/07/11 05:22:55 PM System Log
RainMachine Custom Control 1 1 Thu 2019/07/11 05:23:09 PM System Log
DSC Alarm Custom Control 11 -1 Thu 2019/07/11 05:23:25 PM System Log
RainMachine Custom Control 1 -1 Thu 2019/07/11 05:23:39 PM System Log
DSC Alarm Custom Control 11 1 Thu 2019/07/11 05:23:55 PM System Log
RainMachine Custom Control 1 1 Thu 2019/07/11 05:24:09 PM System Log
DSC Alarm Custom Control 11 -1 Thu 2019/07/11 05:24:25 PM System Log
RainMachine Custom Control 1 -1 Thu 2019/07/11 05:24:40 PM System Log
DSC Alarm Custom Control 11 1 Thu 2019/07/11 05:24:55 PM System Log
RainMachine Custom Control 1 1 Thu 2019/07/11 05:25:10 PM System Log
DSC Alarm Custom Control 11 -1 Thu 2019/07/11 05:25:25 PM System Log
RainMachine Custom Control 1 -1 Thu 2019/07/11 05:25:40 PM System Log
DSC Alarm Custom Control 11 1 Thu 2019/07/11 05:25:55 PM System Log
RainMachine Custom Control 1 1 Thu 2019/07/11 05:26:11 PM System Log
DSC Alarm Custom Control 11 -1 Thu 2019/07/11 05:26:25 PM System Log
RainMachine Custom Control 1 -1 Thu 2019/07/11 05:26:41 PM System Log
DSC Alarm Custom Control 11 1 Thu 2019/07/11 05:26:55 PM System Log
RainMachine Custom Control 1 1 Thu 2019/07/11 05:27:11 PM System Log
DSC Alarm Custom Control 11 -1 Thu 2019/07/11 05:27:25 PM System Log
RainMachine Custom Control 1 -1 Thu 2019/07/11 05:27:42 PM System Log
DSC Alarm Custom Control 11 1 Thu 2019/07/11 05:27:55 PM System Log
RainMachine Custom Control 1 1 Thu 2019/07/11 05:28:12 PM System Log
DSC Alarm Custom Control 11 -1 Thu 2019/07/11 05:28:25 PM System Log
  • 3 months later...
I am having the same Envisalink 3 password issue that others have reported.  I tried entering just the first 6 characters in the password field but that didn't help.  I then reduced the password to just 6 characters but still no luck.  Here is the error as reported.  The disarm password is the 4 digit code right?  Just making sure.  If that is wrong would it generate this error?  There are also some ISY errors reported, are those related?
Thanks io_guy
2019-10-31 16:47:19 - ISY NodeLink Server v0.10.1 started
2019-10-31 16:47:19 - OS: Linux raspberrypi 4.19.75-v7+ #1270 SMP Tue Sep 24 18:45:11 BST 2019 armv7l GNU/Linux
2019-10-31 16:47:19 - Web config server started (http://192.168.1.xxx:8090)
2019-10-31 16:47:19 - ISY resolved to 192.168.1.xxx (5.0.15A)
2019-10-31 16:47:19 - ISY Error: Received an invalid status line: 'POST reuse HTTP/1.1'. (profiles/ns/0/connection)
2019-10-31 16:47:19 - ISY Error: Error getting Node Server list - Root element is missing.
2019-10-31 16:47:19 - ISY Node Server profile set to 1
2019-10-31 16:47:21 - ISY Error: Received an invalid status line: 'POST reuse HTTP/1.1'. (profiles/family/10/profile/1/download/EDITOR/I_EDIT.XML)
2019-10-31 16:47:22 - Warning: Node definitions need updating in ISY, see NodeLink's Devices page
2019-10-31 16:47:22 - DSC: EVL User Login - Password Incorrect [dsc1]
2019-10-31 16:47:23 - Relay Server: Started on port 2405
Yep there's a new bug that the password can't be set.  I'm releasing an update to fix it tonight.
How do I force the upgrade?  Normally I just let Nodelink check in the middle of the night.  Rerun the install script or is there another script for that.
If you restart NodeLink it'll check on startup (assuming you have auto-update enabled).
I also added a check button to 0.10.3 (not released yet).
Then just manually download it, or delete the file and re-run the install script.
Should be an error in your log if it's not connecting to the update server properly.
I deleted the file and re-ran the script.  0.10.2 is now running and the password is accepted.  DSC nodes appear in the ISY and are tracking the actual zone activity.  Thank you for fixing the password issue so quickly!
One last problem.  I cannot communicate with the DSC from ISY using network resources.  I use Command Outputs 1 & 2 in my automation.
I have the relay server enabled in Nodelink
The port defaulted to 2405, I tried that without success, then I switched it to 2402 which was the setting in DSClink.  Still no luck.
The main web display shows that the relay port is starting successfully
I couldn't find a error log file to check in the Node folder on my pi.
What else can I check?
Enable debug or information on the NodeLink "System Config" page and the log window.  You should see a request coming from the ISY when you send the ISY resource.
I enabled debug, see screen shot of the log.  The last 9 entries are the result of sending 3 different commands from ISY.  The first was a status request, the 2nd was to Command Output 1 on, and the 3rd was Command Output 2 on.  All 3 entries seem to be identical and if I'm reading it right it looks like DSC is acknowledging a command of 000, (500 000 25) in all cases.
Using DSCLink I sent Command Output 2 from ISY.  I can see DSC acknowledges the output command 020 in the 4th entry.
You didn't enable the debug on the System Config page, can't see what you're sending through the relay server.
You're using the Relay Server, you should be using the repeater function on the DSC tab.
Thanks io_guy, I switched to the repeater and it is now working.  I used the relay server in DSClink and just thought it would be the same for Nodelink.  Thanks again for all of the troubleshooting help.
