Insteon Swithes flashing
Recently we had storms roll through and probably some power issues (I was at work).  Now i have several switches that are flashing in one way or another.  One has the LED's on the side flashing, others are flashing RED and some are flashing GREEN.  All switches are functioning normally and I tried to restore them and that did not work.  How can i get these switches to stop flashing?
Brian
Factory reset each one, and then restore it.
You better get some methods in place  to prevent this from going through your house in the future. It sounds like the lightning got into your wiring. This may get costly and annoying, and not just for Insteon. If you do not understand electrical discharge phenomenon, look for a sharp electrician.
Brian
Try doing a factory reset on the devices then do a restore device from the ISY
