RemoteLinc Program Scene
I have setup a program to tun on and off some lights. The event is triggered by a button on the remotelinc. The remotelinc button is not linked to anything. The program never sees the trigger. THoughts
Hi KenUD,
The first thing I would suggest is to:
1. Open Tools | Diagnostics | Event Viewer
2. Change the level to 3
3. Click on any of the buttons on your RL and see if there is any traffic in the Event Viewer
If you do see traffic on the Event Viewer, then please copy/paste your program here so that we can check it for problems.
If you do not see any traffic in the Event Viewer, it means that ISY is not hearing the signals from your RL the causes of which may include:
1. There's no Access Point that bridges the RL to the PLM (if your RL is too far from your PLM, then you would need two access points)
2. Noise on the line
3. The PLM does not have the slave links for the RL. For this, you can go to Tools | Diagnostics | Show Device Links Table and choose your RL. After you are done, click on the Compare button. If you have any mismatches, then please restore your RL
Please do keep us posted.
Well I did the event viewer. I dont see any of the traffic from any of my RemoteLincs. I just tried several other SwitchLincs and I dont see any traffic. Yet my timed events work fine and I can communicate to the devices. I did do a restore on the RL but no change.
Hi Ken -
Do any of your Insteon devices update in the Admin Console when you control them locally? It sounds like you are missing links to your PLM.
What version PLM are you running?
Ken, please plug an Access Point directly into the PLM and check again for signals from the RemoteLinc.
Rand
I am running v79 on the PLM and no I dont see any links in the PLM
Well you were right. I replaced the PLM and everything is working well. Too bad I had to waste your time because the Smarthome device wasnt working. Thanks for your outstanding and prompt help
