zwave addon, worked fine until august lock
isy 5013d
zwave addon, version 21100
added three GE switches, everything worked fine, then tried to add an august lock ... now nothing zwave works anymore, if i put it in learning mode, or add .. nothing responds.
i have one of the ge switches right next to the isy controller to avoid distance issues .. click the switch on/off while in learn/add mode .. nothing .. it sits there forever.
who has a clue to either remove or start from scratch .. or reset, powercycle isy did not help at all.
thanks !
thanks, here they are:
august gen 2 lock
GE ZW4103 switches
isy 5013d
When you say nothing works, What specifically isn't working? When it comes to troubleshooting details matter. Are you saying the ge switches no longer work either? Are you able to query them and get status? Are you able to control them from the console? If manually controlled do the changes show up in the ISY?
Are both the firmware and UI 5.13? Was the August lock within 3 feet when you tried to exclude and then add?
the ge switches were added, and worked, then the august lock was added, and everything stopped, i cannot remove/add any of the zwave devices, all insteon is still functional.
the lock was within 3 feet from one of the switches
i am using the java shortcut, so i am assuming it's using the same UI version, since it pulls it from the isy device itself
hope this helps.
i guess what i am looking for is a way to completely get the zwave devices removed, so i can add them again without the august
The lock will need to be very close to the ISY.  Those GE switches do not use security and will not be used for a secure inclusion of the lock.
at this point i do not need the august added to the zwave network, but yes it was within 3 feet
thanks
If you reset the z-wave you will need to exclude all of the devices that were previously included to the z-wave network.
yup, just found the 'hold button for 3 secs after fresh plugin' .. all is back again .. thanks guys !
