NTP connection stopped working
Team:  I have had my ISY994i in place for about a year or more.  I just installed a new router, and I see that since that date, my NTP synchronization is failing and i have a red ! on the config page by the server name.  The error is: NTP SERVER NOT RESPONDING
System    -60006    n/a
Thu 2019/06/20 05:48:54 PM    System    -60006    n/a
Thu 2019/06/20 05:48:54 PM    System    -60006    Stopping retries/next cycle
Fri 2019/06/21 05:50:29 PM    System    -60006    n/a
Fri 2019/06/21 05:50:34 PM    System    -60006    n/a
Fri 2019/06/21 05:50:39 PM    System    -60006    n/a
Fri 2019/06/21 05:50:44 PM
I can ping pool.ntp.org
I have tried putting in an IP address, instead of the name
both of the above make no difference.
I am assuming that my new router is blocking a port that the ISY needs for the time protocol
all of my PCs at home are synchronizing just fine.
Any suggestions?  I am assuming that there are some protocols or ports that I need to be certain are open??
Thanks in advance for the help...
NTP sends from a random UDP port above 1023, to port 123. Your firewall needs to allow that out. It should create a session state to allow the NTP server to send the response back.
  • 5 months later...
Just noticed this is now occurring on my system. New router was installed about 6 months ago, but just noticed error today. What needs to be done on the local router to fix this?
Hello, note that I am using a highly configurable Cisco commercial router.  I essentially had to enable all UDP routes.  My commands were...
Permit UDP any eq ntp
Permit UDP any any eq domain
Permit UDP any eq bootps any eq boot pc
Essentially, you will need to find out how to oent the UDP paths for your specific router.
I hope that this helps.
Good day,
