Qubino Flush 1D as Garage Door Controller
I’m attempting to use the Qubino Flush 1D as a garage door controller.  There a lot to like about this z-wave plus relay, including small size and price.  However I am running into some issues configuring it as a garage door controller.  I got a magnetic reed switch working on it as a door open/close sensor, but the issue I am having is that it cannot be configured as a momentary switch to signal the garage door to open/close.  It is only on/off.  The only work around I have found so far is setting one of the parameters to turn off the switch off after one second when  it is switched on to act like a momentary switch.
  This works, but i have to send an on/off/on every time I want to open and close the door and I end up having the icon in Agave for the garage showing open when the door is closed. I was wondering if anyone else has used the Qubino to control their garage door.  Attached is the diagram of how it is wired.
Qubino Wiring Diagram.pdf
@Joe B, I got this from our contact at Qubino:
»Usually for the garage door the use is exactly as you described the in your post. The 1D relay have to be set with a delayed Off since the garage doors need just a pulse to start open/close movement. In the UI you have to set the sensor as the device that tells you the status of the door.«
The wiring diagram unfortunatelly doesn't open on the forum, it says that the content is not available anymore. If the customer is still unable to solve the problem, he/she can always reach out to our support https://support.qubino.com/support/home. We get back to customers within 24hours.
