Control 'Inside / Inside RL4 Irrigation On' is switched Fast On
Hi,
I'm working through the irrigation program found here:
https://wiki.universal-devices.com/index.php?title=ISY-99i/ISY-26_INSTEON:Auto_Irrigation_Program_v2
and here:
https://www.universal-devices.com/docs/isy99_userguide.pdf
I'm interpreting everything easily except the controls for the "manual" section where it has fast on, fast off etc. The part that I am not getting are all the 'control' commands that begin:
 Control 'Inside / Inside RL4 Irrigation On' is switched ...
My drop down box here contains all my insteon devices EXCEPT my E-Z Flora controller which I assume is what you want to see.
So what does 'Inside / Inside RL4 Irrigation On' detect? There is no description in either source that I can find.
Probably a simple answer, but I need some help on this one.
