Issue with 2.4.11
I noticed on my scenes if for instance I change the on level and/or ramp rate on the first device in the scene it changes the level and/or ramp rate on all the first devices in all my other scenes. The same happens if you change the second device it changes them on all the second devices and so forth.
I deleted and recreated my scenes and backup and restored and they work until you restore when all the scenes are loaded as 50% and a rate of zero and all the first devices are attached together across all scenes and the second to the second and so forth.
After I saw they were not right. I created a new one and it was okay. So I deleted the ones that were broken and recreated them and they were okay. So I did a backup and restore to find out if that did it and found that they were messed up again after the restore. I found out later if I re-installed the firmware it fixed the broken ones. So my best guess right now is the restore breaks them and re-installing the firmware fixes them.
Lets say you have scene 1 and it has a device A in it. Now you have a scene 2 and you have a device B in it. If you go to the scene 1 settings and you set device A to a level of 50%. If you go to scene 2 settings and look at device B you'll see it has also been set to 50%. If you had another scene 3 and a device C you would find it also set to 50%.
RLIKWARTZ,
Apologies for the delay in my reply. We were trying to test this scenario and unfortunately could not reproduce it. This said, however, I do have a few more questions (if you don't mind):
1. Did you follow up your File->Restore ISY with File->Restore Devices ?
2. The numbers you are referring to, say 50% etc, are they the numbers in the Status column on the table on the top part of the view (to your right) or the values of the sliders at the bottom half of the view?
I didn't to a device restore, but I've not been able to reproduce the problem either, but I've done a few things since then so maybe I cleared it. I now have a new issue. My scenes no longer work. When I turn one on it doesn't turn the lights on that are in it like it did before. I can control the individual devices in the scene
I did a device restore and everything works including the scenes. I think I'm set now. Thanks for the response and pointing this out.
