Please help installing Polyglot
11 minutes ago, simplextech said:
Did you preface the command with pi@
ssh pi@<ip>
on Mac it may be different for the user so try
ssh -l pi <ip>
otherwise if the username is not the default then I wouldn't know.  It will be the same as what you used logging in with a keyboard and monitor attached.  The only other possibility is back to SSH not actually running which is why you can't get remote access.  Even without the remote access if everything else ran correctly during your install then you shouldn't really need it that much.
If it's logging into the pi and asking for the password then SSH must be working.  Do you agree?
If it's connecting and you're getting a password prompt then SSH would be working.
why it's not taking the password would be a typo or ssh not allowing the login which by default it should so again I dunno.
ssh pi@<ip>
ssh -l pi <ip>
I tried to change password in terminal of the pi.  Typed passwd.  Entered raspberry for current password and it said authentication token manipulation error.  I swear I didn't change the password.  But this means it must not be raspberry, right?
Why complicate thing logging in remotely with SSH when you already have a terminal window connected directly into a RPi. SSH has to be set up to run on the RPi and then the TTY client has to be setup at the remote end. The install crashed on the RPI. The install problems needs to be fixed first.
Is there some reason to add the SSH complications to this right now? Is it thought remote access will make the install work? If you are running the GUI screens locally on the RPi you have access to so many more tools to assist you simultaneously in a multi-user style O/S.
5 minutes ago, simplextech said:
ok... try whatever you thought you changed it to.
OK I was able to log in.  I ran the polyglot install script.  It says it is installed and gives me the https: address to go to.  When I go to the address, browser says invalid page.  I tried Chrome.  This is the same problem I had before.  Only thing I did different this time is that I installed polyglot from my Mac.  Any thoughts?
I was able to get SSH to work, but you are right, I can just use the terminal in pi since it is hooked up to screen.  I'm still having the same issue as before.  Got message that polyglot is installed and gave me the https address to go to, but it says can't connect when I try in my Mac browser.  Used Chrome and Safari.  Any thoughts?
Are you getting a security error?
Polyglot was never finished with the security certificates to enable your browser to comfortably access the webpage server that it will ask you for.. If so, just ignore the error and proceed to the page anyway as a trusted page.
Nope.  Here's a screenshot.  https://imgur.com/vDqVMtR
Also post the output of
ps -ef |grep polyglot
I suspect both will be empty no results which would confirm that polyglot just really is not running and not installed fully/correctly at which point I don't know where to even start trying to troubleshoot.  If you did a fresh install with buster lite and ran the install exactly as the command is written then it should "just work".  I did this myself today and everything installed and was fine.
2 minutes ago, simplextech said:
From the pi console run the following...
netstat -an |grep 3000
Post those results
bash:  grep3000: command not found
you're missing half of the command....
the commands must be typed exactly spaces and other characters have meaning.
pi@raspberrypi:~ $ ps -ef |grep polyglot
pi        2066     1  0 18:07 ?        00:00:05 /home/pi/polyglot/polyglot-v2-linux-armv7
pi        2279  1820  0 19:02 pts/1    00:00:00 grep --color=auto polyglot
pi@raspberrypi:~ $
I actually typed the whole command before.  Maybe I got a character off.  This time I copied paste and the command returned nothing.
run this....
netstat -an |grep tcp |grep LISTEN
that should return something.  I'm curious if polyglot is listening on tcp6 as it's not showing on tcp
Just now, simplextech said:
run this....
pi@raspberrypi:~ $ netstat -an |grep tcp |grep LISTEN
tcp        0      0 127.0.0.1:27017         0.0.0.0:*               LISTEN
tcp        0      0 127.0.0.1:28017         0.0.0.0:*               LISTEN
tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN
tcp6       0      0 :::22                   :::*                    LISTEN
ok so polyglot just isn't listening on any port anywhere.
Have you tried rebooting the raspberry pi?
Just tried.  Didn't help.
check the processes again and the netstat.  I want to see if polyglot is running but doesn't have a listening port.
pi         334     1  2 19:11 ?        00:00:04 /home/pi/polyglot/polyglot-v2-linux-armv7
pi         983   971  0 19:15 pts/1    00:00:00 grep --color=auto polyglot
pi@raspberrypi:~ $
This next test will require you to edit a file.
  • Filename:
    • /boot/cmdline.txt
  • Entry to Add:
    • ipv6.disable=1
From the command line you can use vi or nano
sudo nano /boot/cmdline.txt
Add the ipv6.disable=1 entry to the very end of the line in the file.  There are spaces between the different parameters.
Example:
dwc_otg.lpm_enable=0 console=serial0,115200 console=tty1 root=PARTUUID=c0f35752-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait ipv6.disable=1
Save this file and then reboot.
