ployglot help
This is the error i get when I tried to give udi permission to my nest througt polyglot:
Oops! We’ve encountered an error. Please try again.
Works with Nest
Universal Devices, Inc. would like to do the following:
    Control temperature and thermostat settings.
    Allow ISY to see and change your thermostat settings
    See that you’re enrolled in Rush Hour Rewards and see Rush Hour start and end times.
    Allow ISY to see your rush hour reward status
    See your camera’s settings, turn it on or off, show images or video when there’s sound or motion, and share your video stream if it’s public.
    Allow ISY to see your camera status and start/stop stream
    See your Nest Protect’s smoke, carbon monoxide, and battery info.
    Allow ISY to see your smoke detector status
    See the security state of your Nest home.
    Allow ISY to see the state of the structure security status
    Set Home and Away.
    Allow ISY to see and change your structure home/away status
Learn more about the categories of data Nest will share with Universal Devices, Inc. if you grant this permission. By selecting Allow, you allow Universal Devices, Inc. to receive and use this information as explained above and in accordance with its terms of service and privacy policy. If you want to revoke this permission and stop working with Universal Devices, Inc. at any time, go to Home settings in the Nest app.
Edited by lurlette
Works with Nest
    Set Home and Away.
Google announced a while back that it was ending the works with nest program. Anything not set up prior to the end of Aug would not be allowed
