6 Button KPL and Restore Device mode
I have some questions regarding the restore function for a 6 button KPL.
Do you manually restore each node, or by restoring one do all 5 get restored?
If the load is controlled by a motion sensor (2420) do you have to enter setup mode on the MS before restoring?
Tim
Hello Tim,
You only need to restore one of the buttons and all get restored.
No, you do not to put MS in programming mode since restoration is simply recreating all the links in the KPL.
Tim
Hi Michel,
Thanks for the reply, one more thing. If you press File > Restore devices from the top of the administration console and you don’t enter setup on MS’s, will the ISY restore all devices it can and bypass devices not in setup mode? Or will it stop when it cant restore one of the devices?
Tim
Hi Tim,
I will NOT stop and will continue ... but, the process is going to take much longer since ISY tries to communicate with them at least 3 times before it gives up on them.
Hi Michel,
Tim
