DSC Envisalink
2019-11-11 13:47:15 - ISY NodeLink Server v0.10.2 started
2019-11-11 13:47:15 - OS: Microsoft Windows NT 6.2.9200.0
2019-11-11 13:47:15 - Web config server started (http://192.168.2.69:8090)
2019-11-11 13:47:17 - ISY resolved to 192.168.1.5 ()
2019-11-11 13:47:18 - ISY Error: No connection could be made because the target machine actively refused it. (profiles/ns/0/connection)
2019-11-11 13:47:18 - ISY Error: Error getting Node Server list - Root element is missing.
2019-11-11 13:47:18 - ISY Node Server profile set to 1
2019-11-11 13:47:20 - ISY Error: No connection could be made because the target machine actively refused it. (ns/1/nodes/n001_dsc1_z01/report/status/ST/0/25)
I'm having a heck of time with DSC link ever since I registered it with the Invisalink portal.  As best I can figure, the issue is that my ISY/nodelink are not on the same LAN as the envisalink, but rather to LAN's linked by router to router vpn tunnel (Unifi).  So, as a test, I thought I would run nodelink in the lan with the dsc, but it looks like I'm getting a similar problem.  Envisalink refuses connection from Nodelink when not at the same lan, and ISY refuses Nodelink when at a different lan.  Ideas?
I can't even browse to the envisalink lan ip address from the remote lan.  I get an error of refusal from envisalink.  I have never had issues accessing things back and forth through my vpn tunnel ever before just using the lan ip address.  For example, I run the UD admin console, access ip cameras, run elk rp, use remote desktop, etc on any pc on either lan without issue using the LAN IP.  What is special about these nodelink connections?
In the above example, I ran nodelink with admin privileges using the configuration file from nodelink that was running fine on the pc in the same lan (I shut that nodelink down before running this one).
Edited by apostolakisl
Not sure what I can do with NodeLink.  Seems like it's the EVL and/or the ISY refusing the connections.
Yeah, I just don't get it.  Obviously it is making contact, but why does it refuse the connection just because it is being routed through a vpn tunnel?
It's pretty common for devices to refuse connection to addresses outside their immediate subnet for security.  The EVL may have received a firmware update enabling this after you enrolled it with the portal.
Do you know if ISY has this property?  Nodelink is getting an explicit denial from ISY when on the other side of the vpn tunnel, similar to envisalink denial to nodelink.  The admin console is not getting denied when access via the vpn tunnel.
You nailed it.  They updated the firmware.  Never told me it updated or asked for permission or anything, so how was I to know?  What you have to do is change the password from default and then it works.
@io_guy
I wanted to send an email when disarmed including the user.  Is there a way to use variable substitution directly with that value?  I wasn't able to figure out what node that would be.  I ended up posting it to a variable and then substituting the variable into the email.  It works, but adds complexity.
Also, the state of the outputs is not correct.  This was also true with the polyglot version of dsc node server.  My output turns on upon arming the system and it is confirmed to be working.  Yet the node servers continue to say it is off.  Any idea on that?  Does the output state only correctly show when turned on/off manually?
Lastly, it says my partition 1 is not ready to be armed even though it is (partition 2 shows correctly).  Again, the polyglot version does too.  I have two zones that are designated as "24 hour non-burglary" which are both open most of the time, so I thought maybe they are the reason?  These zones don't affect the keypads, or the envisalink UI.  Both of them say "ready", but the NS's say "not ready".  Those two zones may have nothing to do with it though.
The last two points are the same with both your NS and the polyglot one, so whatever it is, it must be some sort of discrepancy in the API?
The disarming user is GV1.
In order to help with the other ones I need a debug log.  Enable debug on the DSC tab and on the main log display (or save to file) and let me know what action I'm looking for.
Great!   ${sys.node.n001_dsc1.GV1} works.
I'll get the other stuff going.  Thanks.
Under the DSC tab, I set to log to "debug" level.  On the main screen, I checked the box "lot to file".  I just checked the file, and it isn't showing what I would consider "debug" info.  I would expect, for example, every zone violation/restoral to be there.  But so far, hardly anything despite quite a bit of such activity.  This is it:
2019-11-13 09:15:23 - ISY Error: Timeout from the ISY (ns/1/nodes/n001_dsc1/report/status/GV11/-1/25) [5]
2019-11-13 09:19:08 - DSC: System Status - Entry Delay In Progress (Partition 2) [dsc1]
2019-11-13 09:19:19 - DSC: System Status - Disarmed (Partition 2) [dsc1]
EDIT:  OK, restarted nodelink and now I am getting copious info:
@io_guy
2019-11-13 11:05:51 - ISY NodeLink Server v0.10.2 started
2019-11-13 11:05:51 - OS: Microsoft Windows NT 6.2.9200.0
2019-11-13 11:05:51 - Web config server started (http://192.168.1.71:8090)
2019-11-13 11:05:52 - ISY resolved to 192.168.1.9 (5.0.16)
2019-11-13 11:05:52 - ISY Node Server config detected (profile 1)
2019-11-13 11:05:53 - Auto-Update: Error updating file: The remote server returned an error: (404) Not Found.
2019-11-13 11:05:54 - ISY Warning: Duplicate node names exist on the ISY (Door Fire Escape)
2019-11-13 11:05:54 - ISY Warning: Duplicate node names exist on the ISY (Door Cadiz)
2019-11-13 11:05:54 - ISY Warning: Duplicate node names exist on the ISY (Doorbell Akesis)
2019-11-13 11:05:54 - ISY Warning: Duplicate node names exist on the ISY (Doorbell Fire Escape)
2019-11-13 11:05:54 - ISY Warning: Duplicate node names exist on the ISY (Motion Front)
2019-11-13 11:05:54 - ISY Warning: Duplicate node names exist on the ISY (Motion Back)
2019-11-13 11:05:54 - ISY Warning: Duplicate node names exist on the ISY (Door Akesis)
2019-11-13 11:05:54 - ISY Warning: Duplicate node names exist on the ISY (Ellens S8)
2019-11-13 11:05:54 - ISY Warning: Duplicate node names exist on the ISY (Door Front)
2019-11-13 11:05:54 - ISY Warning: Duplicate node names exist on the ISY (Lous S8)
2019-11-13 11:05:54 - ISY Warning: Duplicate node names exist on the ISY (Door Kitchen to Cadiz)
2019-11-13 11:05:55 - DSC: Connected to 192.168.2.141 [dsc1]
2019-11-13 11:05:55 - DSC: 5053CD[C][L] [dsc1]
2019-11-13 11:05:55 - DSC: 505 - Login Interaction (Password Requested) [dsc1]
2019-11-13 11:05:55 - DSC: EVL User Login - Password Sent [dsc1]
2019-11-13 11:05:55 - DSC: 5000052A[C][L]5051CB[C][L] [dsc1]
2019-11-13 11:05:55 - DSC: 500 - Command Acknowledge (005) [dsc1]
2019-11-13 11:05:55 - DSC: 505 - Login Interaction (Password Correct, Session Established) [dsc1]
2019-11-13 11:05:55 - DSC: Status Request Sent [dsc1]
2019-11-13 11:05:55 - DSC: Data Sent - 00191 [dsc1]
2019-11-13 11:05:55 - DSC TCP: Polling DSC [dsc1]
2019-11-13 11:05:55 - DSC: 50000126[C][L]61000128[C][L]60900231[C][L]6100032A[C][L]60900433[C][L]6100052C[C][L]6100062D[C][L]60900736[C][L]6100082F[C][L]61000930[C][L]61001028[C][L]61001129[C][L]6100122A[C][L]6100132B[C][L]6100142C[C][L]6100152D[C][L]6100162E[C][L]6100172F[C][L]61001830[C][L]61001931[C][L]61002029[C][L]6100212A[C][L]6100222B[C][L]6100232C[C][L] [dsc1]
2019-11-13 11:05:55 - DSC: 500 - Command Acknowledge (001) [dsc1]
2019-11-13 11:05:55 - DSC: 610 - Zone Restored (Zone 001) [dsc1]
2019-11-13 11:05:55 - DSC: Zone 1 (Door Akesis)  Closed [dsc1]
2019-11-13 11:05:55 - DSC: 609 - Zone Open (Zone 002) [dsc1]
2019-11-13 11:05:55 - DSC: Zone 2 (Doorbell Akesis)  Opened [dsc1]
2019-11-13 11:05:55 - DSC: 610 - Zone Restored (Zone 003) [dsc1]
2019-11-13 11:05:55 - DSC: Zone 3 (Door Front)  Closed [dsc1]
2019-11-13 11:05:55 - DSC: 609 - Zone Open (Zone 004) [dsc1]
2019-11-13 11:05:55 - DSC: Zone 4 (Door Cadiz)  Opened [dsc1]
2019-11-13 11:05:55 - DSC: 610 - Zone Restored (Zone 005) [dsc1]
2019-11-13 11:05:55 - DSC: Zone 5 (Door Fire Escape)  Closed [dsc1]
2019-11-13 11:05:55 - DSC: 610 - Zone Restored (Zone 006) [dsc1]
2019-11-13 11:05:55 - DSC: Zone 6 (Motion Front)  Closed [dsc1]
2019-11-13 11:05:55 - DSC: 609 - Zone Open (Zone 007) [dsc1]
2019-11-13 11:05:55 - DSC: Zone 7 (Doorbell Fire Escape)  Opened [dsc1]
2019-11-13 11:05:55 - DSC: 610 - Zone Restored (Zone 008) [dsc1]
2019-11-13 11:05:55 - DSC: Zone 8 (Motion Back)  Closed [dsc1]
2019-11-13 11:05:55 - DSC: 610 - Zone Restored (Zone 009) [dsc1]
2019-11-13 11:05:55 - DSC: Zone 9 (Door Kitchen to Cadiz)  Closed [dsc1]
2019-11-13 11:05:55 - DSC: 610 - Zone Restored (Zone 010) [dsc1]
2019-11-13 11:05:55 - DSC: 610 - Zone Restored (Zone 011) [dsc1]
2019-11-13 11:05:55 - DSC: 610 - Zone Restored (Zone 012) [dsc1]
2019-11-13 11:05:55 - DSC: 610 - Zone Restored (Zone 013) [dsc1]
2019-11-13 11:05:55 - DSC: 610 - Zone Restored (Zone 014) [dsc1]
2019-11-13 11:05:55 - DSC: 610 - Zone Restored (Zone 015) [dsc1]
2019-11-13 11:05:55 - DSC: 610 - Zone Restored (Zone 016) [dsc1]
2019-11-13 11:05:55 - DSC: 610 - Zone Restored (Zone 017) [dsc1]
2019-11-13 11:05:55 - DSC: 610 - Zone Restored (Zone 018) [dsc1]
2019-11-13 11:05:55 - DSC: 610 - Zone Restored (Zone 019) [dsc1]
2019-11-13 11:05:55 - DSC: 610 - Zone Restored (Zone 020) [dsc1]
2019-11-13 11:05:55 - DSC: 610 - Zone Restored (Zone 021) [dsc1]
2019-11-13 11:05:55 - DSC: 610 - Zone Restored (Zone 022) [dsc1]
2019-11-13 11:05:55 - DSC: 610 - Zone Restored (Zone 023) [dsc1]
2019-11-13 11:05:55 - DSC: 50000025[C][L]60900332[C][L] [dsc1]
2019-11-13 11:05:55 - DSC: 500 - Command Acknowledge (000) [dsc1]
2019-11-13 11:05:55 - DSC: 609 - Zone Open (Zone 003) [dsc1]
2019-11-13 11:05:55 - DSC: Zone 3 (Door Front)  Opened [dsc1]
2019-11-13 11:05:55 - DSC: 51090FF[C][L] [dsc1]
2019-11-13 11:05:55 - DSC: 510 - Full LED Status Update [dsc1]
2019-11-13 11:05:55 - DSC: 6511CD[C][L] [dsc1]
2019-11-13 11:05:55 - DSC: 651 - Partition Not Ready (Partition 1) [dsc1]
2019-11-13 11:05:55 - DSC: System Status - Not Ready (Partition 1) [dsc1]
2019-11-13 11:05:55 - DSC: System Status - Disarmed (Set By Status Request - Partition 1) [dsc1]
2019-11-13 11:05:56 - DSC: 6100242D[C][L]6100252E[C][L]6100262F[C][L]61002730[C][L]61002831[C][L]61002932[C][L]6100302A[C][L]6100312B[C][L]6100322C[C][L]6100332D[C][L]6100342E[C][L]6100352F[C][L]61003630[C][L]61003731[C][L]61003832[C][L]61003933[C][L]6100402B[C][L]6100412C[C][L]6100422D[C][L]6100432E[C][L]6100442F[C][L]61004530[C][L]61004631[C][L]61004732[C][L] [dsc1]
2019-11-13 11:05:56 - DSC: 610 - Zone Restored (Zone 024) [dsc1]
2019-11-13 11:05:56 - DSC: 610 - Zone Restored (Zone 025) [dsc1]
2019-11-13 11:05:56 - DSC: 610 - Zone Restored (Zone 026) [dsc1]
2019-11-13 11:05:56 - DSC: 610 - Zone Restored (Zone 027) [dsc1]
2019-11-13 11:05:56 - DSC: 610 - Zone Restored (Zone 028) [dsc1]
2019-11-13 11:05:56 - DSC: 610 - Zone Restored (Zone 029) [dsc1]
2019-11-13 11:05:56 - DSC: 610 - Zone Restored (Zone 030) [dsc1]
2019-11-13 11:05:56 - DSC: 610 - Zone Restored (Zone 031) [dsc1]
2019-11-13 11:05:56 - DSC: 610 - Zone Restored (Zone 032) [dsc1]
2019-11-13 11:05:56 - DSC: 610 - Zone Restored (Zone 033) [dsc1]
2019-11-13 11:05:56 - DSC: 610 - Zone Restored (Zone 034) [dsc1]
2019-11-13 11:05:56 - DSC: 610 - Zone Restored (Zone 035) [dsc1]
2019-11-13 11:05:56 - DSC: 610 - Zone Restored (Zone 036) [dsc1]
2019-11-13 11:05:56 - DSC: 610 - Zone Restored (Zone 037) [dsc1]
2019-11-13 11:05:56 - DSC: 610 - Zone Restored (Zone 038) [dsc1]
2019-11-13 11:05:56 - DSC: 610 - Zone Restored (Zone 039) [dsc1]
2019-11-13 11:05:56 - DSC: 610 - Zone Restored (Zone 040) [dsc1]
2019-11-13 11:05:56 - DSC: 610 - Zone Restored (Zone 041) [dsc1]
2019-11-13 11:05:56 - DSC: 610 - Zone Restored (Zone 042) [dsc1]
2019-11-13 11:05:56 - DSC: 610 - Zone Restored (Zone 043) [dsc1]
2019-11-13 11:05:56 - DSC: 610 - Zone Restored (Zone 044) [dsc1]
2019-11-13 11:05:56 - DSC: 610 - Zone Restored (Zone 045) [dsc1]
2019-11-13 11:05:56 - DSC: 610 - Zone Restored (Zone 046) [dsc1]
2019-11-13 11:05:56 - DSC: 610 - Zone Restored (Zone 047) [dsc1]
2019-11-13 11:05:56 - DSC: 61004833[C][L]61004934[C][L]6100502C[C][L]6100512D[C][L]6100522E[C][L]6100532F[C][L]61005430[C][L]61005531[C][L]61005632[C][L]61005733[C][L]61005834[C][L]61005935[C][L]6100602D[C][L]6100612E[C][L]6100622F[C][L]61006330[C][L]61006431[C][L]6511CD[C][L]6512CE[C][L]6733D3[C][L]6734D4[C][L]6735D5[C][L]6736D6[C][L]6737D7[C][L]6738D8[C][L]8401CD[C][L] [dsc1]
2019-11-13 11:05:56 - DSC: 610 - Zone Restored (Zone 048) [dsc1]
2019-11-13 11:05:56 - DSC: 610 - Zone Restored (Zone 049) [dsc1]
2019-11-13 11:05:56 - DSC: 610 - Zone Restored (Zone 050) [dsc1]
2019-11-13 11:05:56 - DSC: 610 - Zone Restored (Zone 051) [dsc1]
2019-11-13 11:05:56 - DSC: 610 - Zone Restored (Zone 052) [dsc1]
2019-11-13 11:05:56 - DSC: 610 - Zone Restored (Zone 053) [dsc1]
2019-11-13 11:05:56 - DSC: 610 - Zone Restored (Zone 054) [dsc1]
2019-11-13 11:05:56 - DSC: 610 - Zone Restored (Zone 055) [dsc1]
2019-11-13 11:05:56 - DSC: 610 - Zone Restored (Zone 056) [dsc1]
2019-11-13 11:05:56 - DSC: 610 - Zone Restored (Zone 057) [dsc1]
2019-11-13 11:05:56 - DSC: 610 - Zone Restored (Zone 058) [dsc1]
2019-11-13 11:05:56 - DSC: 610 - Zone Restored (Zone 059) [dsc1]
2019-11-13 11:05:56 - DSC: 610 - Zone Restored (Zone 060) [dsc1]
2019-11-13 11:05:56 - DSC: 610 - Zone Restored (Zone 061) [dsc1]
2019-11-13 11:05:56 - DSC: 610 - Zone Restored (Zone 062) [dsc1]
2019-11-13 11:05:56 - DSC: 610 - Zone Restored (Zone 063) [dsc1]
2019-11-13 11:05:56 - DSC: 610 - Zone Restored (Zone 064) [dsc1]
2019-11-13 11:05:56 - DSC: 651 - Partition Not Ready (Partition 1) [dsc1]
2019-11-13 11:05:56 - DSC: System Status - Not Ready (Partition 1) [dsc1]
2019-11-13 11:05:56 - DSC: 651 - Partition Not Ready (Partition 2) [dsc1]
2019-11-13 11:05:56 - DSC: System Status - Not Ready (Partition 2) [dsc1]
2019-11-13 11:05:56 - DSC: System Status - Disarmed (Set By Status Request - Partition 2) [dsc1]
2019-11-13 11:05:56 - DSC: 673 - Partition Busy (Partition 3) [dsc1]
2019-11-13 11:05:56 - DSC: 673 - Partition Busy (Partition 4) [dsc1]
2019-11-13 11:05:56 - DSC: 673 - Partition Busy (Partition 5) [dsc1]
2019-11-13 11:05:56 - DSC: 673 - Partition Busy (Partition 6) [dsc1]
2019-11-13 11:05:56 - DSC: 673 - Partition Busy (Partition 7) [dsc1]
2019-11-13 11:05:56 - DSC: 673 - Partition Busy (Partition 8) [dsc1]
2019-11-13 11:05:56 - DSC: 840 - Trouble Status (LED ON) (Partition 1) [dsc1]
2019-11-13 11:05:56 - DSC: Panel Trouble Present [dsc1]
2019-11-13 11:05:57 - DSC: 8402CE[C][L]8403CF[C][L]8404D0[C][L]8405D1[C][L]8406D2[C][L]8407D3[C][L]8408D4[C][L]51090FF[C][L] [dsc1]
2019-11-13 11:05:57 - DSC: 840 - Trouble Status (LED ON) (Partition 2) [dsc1]
2019-11-13 11:05:57 - DSC: Panel Trouble Present [dsc1]
2019-11-13 11:05:57 - DSC: 840 - Trouble Status (LED ON) (Partition 3) [dsc1]
2019-11-13 11:05:57 - DSC: 840 - Trouble Status (LED ON) (Partition 4) [dsc1]
2019-11-13 11:05:57 - DSC: 840 - Trouble Status (LED ON) (Partition 5) [dsc1]
2019-11-13 11:05:57 - DSC: 840 - Trouble Status (LED ON) (Partition 6) [dsc1]
2019-11-13 11:05:57 - DSC: 840 - Trouble Status (LED ON) (Partition 7) [dsc1]
2019-11-13 11:05:57 - DSC: 840 - Trouble Status (LED ON) (Partition 8) [dsc1]
2019-11-13 11:05:57 - DSC: 510 - Full LED Status Update [dsc1]
2019-11-13 11:05:59 - DSC: 6100032A[C][L] [dsc1]
2019-11-13 11:05:59 - DSC: 610 - Zone Restored (Zone 003) [dsc1]
2019-11-13 11:05:59 - DSC: Zone 3 (Door Front)  Closed [dsc1]
2019-11-13 11:05:59 - DSC: 5109100[C][L] [dsc1]
2019-11-13 11:05:59 - DSC: 510 - Full LED Status Update [dsc1]
2019-11-13 11:05:59 - DSC: 6531CF[C][L] [dsc1]
2019-11-13 11:05:59 - DSC: 653 - Partition in Ready to Force Arm (Partition 1) [dsc1]
2019-11-13 11:06:12 - DSC: 60900332[C][L] [dsc1]
2019-11-13 11:06:12 - DSC: 609 - Zone Open (Zone 003) [dsc1]
2019-11-13 11:06:12 - DSC: Zone 3 (Door Front)  Opened [dsc1]
2019-11-13 11:06:12 - DSC: 51090FF[C][L]6511CD[C][L] [dsc1]
2019-11-13 11:06:12 - DSC: 510 - Full LED Status Update [dsc1]
2019-11-13 11:06:12 - DSC: 651 - Partition Not Ready (Partition 1) [dsc1]
2019-11-13 11:06:12 - DSC: System Status - Not Ready (Partition 1) [dsc1]
2019-11-13 11:06:16 - DSC: 6100032A[C][L] [dsc1]
2019-11-13 11:06:16 - DSC: 610 - Zone Restored (Zone 003) [dsc1]
2019-11-13 11:06:16 - DSC: Zone 3 (Door Front)  Closed [dsc1]
2019-11-13 11:06:16 - DSC: 5109100[C][L] [dsc1]
2019-11-13 11:06:16 - DSC: 510 - Full LED Status Update [dsc1]
2019-11-13 11:06:16 - DSC: 6531CF[C][L] [dsc1]
2019-11-13 11:06:16 - DSC: 653 - Partition in Ready to Force Arm (Partition 1) [dsc1]
Regarding the issue of "ready to arm".  It appears the two zones that are not alarm zones are recognized by dsc as available for force arm.  This shows up on nodelink as "not ready".  Is it possible to add "ready to force arm"?
The duplicate node error it shows is a result of me also having an identical node set up for polyglot.  I currently have that disabled.  I like your version better and plan on using it.
The "trouble' condition is that my battery just went bad.  I'm waiting for the new one.  ISY does not show that there is a trouble condition.  According to the polyglot version author, it only works when the trouble light first comes on with the NS running.  Seems like if it is in the log, then it should be able to come on?  Perhaps the issue is non-specificity (ie, could be any trouble condition).  Perhaps there could be a generic "trouble" condition that isn't specific to it being battery?
I can either add another for Ready to Force or add an option in NodeLink to treat that situation as a standard "ready".  Preference, thinking maybe the option is easier?
The panel trouble should be showing up.  It'll be "Panel Trouble" on the Main Alarm Node (not partition).
For the command output I need a log.  They're not the best for feedback in the API so I'd need to see exactly what's happening.
@io_guy
For me, having an option in nodelink configuration would work.  Ideally you would be able to tell the difference.  Although, neither the keypads nor Envisalink UI tell you the difference, they both just say "ready".  My Elk has the green ready light blink when it is in a force arm ready state vs solid green for full ready.
I'll get the output state change here in about 45 minutes when we lock up for the night.  The output follows the armed state.  Now that ISY can control things, my plan is to have ISY turn it on 45 minutes after arming.  This way our washer can run.  I also have water sensors.  Output 2 follows that zone.  Testing that one will require me setting off the alarm, so let's see what output 1 does first.
And yes, Panel Trouble shows "1".  Sorry for not noticing that.  I'm getting your program and the other one mixed up.  It shows battery trouble as an individual item.
Also, just an fyi, yesterday when nodelink tried to download the update, it showed a "404 error" in the log.
It appears something has gone wrong.  To the best of my knowledge, there have been no network problems, yet there are lots of errors and ISY says "entry delay" even though the system is currently armed.  ISY and Nodelink are on the same lan, DSC is on a vpn connected LAN.
2019-11-13 19:30:55 - DSC TCP: Polling DSC [dsc1]
2019-11-13 19:30:55 - DSC: 50000025[C][L] [dsc1]
2019-11-13 19:30:55 - DSC: 500 - Command Acknowledge (000) [dsc1]
2019-11-13 19:30:57 - ISY Error: Web Error (FAILED) - NotFound (ns/1/nodes/n001_dsc1/report/status/GV1/09/70)
2019-11-13 19:31:31 - ISY Error: Web Error (FAILED) - NotFound (ns/1/nodes/n001_dsc1/report/status/GV1/09/70)
2019-11-13 19:31:55 - DSC TCP: Polling DSC [dsc1]
2019-11-13 19:31:55 - DSC: 50000025[C][L] [dsc1]
2019-11-13 19:31:55 - DSC: 500 - Command Acknowledge (000) [dsc1]
2019-11-13 19:32:06 - ISY Error: Web Error (FAILED) - NotFound (ns/1/nodes/n001_dsc1/report/status/GV1/09/70)
2019-11-13 19:32:40 - ISY Error: Web Error (FAILED) - NotFound (ns/1/nodes/n001_dsc1/report/status/GV1/09/70)
2019-11-13 19:32:54 - DSC: 51110F8[C][L] [dsc1]
2019-11-13 19:32:54 - DSC: 511 - Full LED Status (Flash) Update [dsc1]
2019-11-13 19:32:54 - DSC: 8490106[C][L] [dsc1]
2019-11-13 19:32:54 - DSC: 849 - Verbose Trouble Status Received [dsc1]
2019-11-13 19:32:54 - DSC: 51080FE[C][L]8402CE[C][L] [dsc1]
2019-11-13 19:32:54 - DSC: 510 - Full LED Status Update [dsc1]
2019-11-13 19:32:54 - DSC: 840 - Trouble Status (LED ON) (Partition 2) [dsc1]
2019-11-13 19:32:54 - DSC: Panel Trouble Present [dsc1]
2019-11-13 19:32:54 - DSC: 51100F7[C][L] [dsc1]
2019-11-13 19:32:54 - DSC: 51090FF[C][L]8402CE[C][L] [dsc1]
2019-11-13 19:32:54 - DSC: 6511CD[C][L] [dsc1]
2019-11-13 19:32:54 - DSC: 651 - Partition Not Ready (Partition 1) [dsc1]
2019-11-13 19:32:54 - DSC: System Status - Not Ready (Partition 1) [dsc1]
2019-11-13 19:32:55 - DSC TCP: Polling DSC [dsc1]
2019-11-13 19:32:55 - DSC: 50000025[C][L] [dsc1]
2019-11-13 19:32:55 - DSC: 500 - Command Acknowledge (000) [dsc1]
2019-11-13 19:33:14 - ISY Error: Web Error (FAILED) - NotFound (ns/1/nodes/n001_dsc1/report/status/GV1/09/70)
2019-11-13 19:33:18 - DSC: 6100032A[C][L] [dsc1]
2019-11-13 19:33:18 - DSC: 610 - Zone Restored (Zone 003) [dsc1]
2019-11-13 19:33:18 - DSC: Zone 3 (Door Front)  Closed [dsc1]
2019-11-13 19:33:19 - DSC: 5109100[C][L] [dsc1]
2019-11-13 19:33:19 - DSC: 510 - Full LED Status Update [dsc1]
2019-11-13 19:33:19 - DSC: 6531CF[C][L] [dsc1]
2019-11-13 19:33:19 - DSC: 653 - Partition in Ready to Force Arm (Partition 1) [dsc1]
2019-11-13 19:33:23 - DSC: 60900130[C][L] [dsc1]
2019-11-13 19:33:23 - DSC: 609 - Zone Open (Zone 001) [dsc1]
2019-11-13 19:33:23 - DSC: Zone 1 (Door Akesis)  Opened [dsc1]
2019-11-13 19:33:23 - DSC: 51090FF[C][L] [dsc1]
2019-11-13 19:33:23 - DSC: 510 - Full LED Status Update [dsc1]
2019-11-13 19:33:23 - DSC: 6511CD[C][L] [dsc1]
2019-11-13 19:33:23 - DSC: 651 - Partition Not Ready (Partition 1) [dsc1]
2019-11-13 19:33:23 - DSC: System Status - Not Ready (Partition 1) [dsc1]
2019-11-13 19:33:25 - DSC: 61000128[C][L] [dsc1]
2019-11-13 19:33:25 - DSC: 610 - Zone Restored (Zone 001) [dsc1]
2019-11-13 19:33:25 - DSC: Zone 1 (Door Akesis)  Closed [dsc1]
2019-11-13 19:33:25 - DSC: 5109100[C][L] [dsc1]
2019-11-13 19:33:25 - DSC: 510 - Full LED Status Update [dsc1]
2019-11-13 19:33:25 - DSC: 6531CF[C][L] [dsc1]
2019-11-13 19:33:25 - DSC: 653 - Partition in Ready to Force Arm (Partition 1) [dsc1]
2019-11-13 19:33:31 - DSC: 60900332[C][L] [dsc1]
2019-11-13 19:33:31 - DSC: 609 - Zone Open (Zone 003) [dsc1]
2019-11-13 19:33:31 - DSC: Zone 3 (Door Front)  Opened [dsc1]
2019-11-13 19:33:31 - DSC: 51090FF[C][L] [dsc1]
2019-11-13 19:33:31 - DSC: 510 - Full LED Status Update [dsc1]
2019-11-13 19:33:31 - DSC: 6511CD[C][L] [dsc1]
2019-11-13 19:33:31 - DSC: 651 - Partition Not Ready (Partition 1) [dsc1]
2019-11-13 19:33:31 - DSC: System Status - Not Ready (Partition 1) [dsc1]
2019-11-13 19:33:36 - DSC: 6100032A[C][L] [dsc1]
2019-11-13 19:33:36 - DSC: 610 - Zone Restored (Zone 003) [dsc1]
2019-11-13 19:33:36 - DSC: Zone 3 (Door Front)  Closed [dsc1]
2019-11-13 19:33:36 - DSC: 5109100[C][L] [dsc1]
2019-11-13 19:33:36 - DSC: 510 - Full LED Status Update [dsc1]
2019-11-13 19:33:36 - DSC: 6531CF[C][L] [dsc1]
2019-11-13 19:33:36 - DSC: 653 - Partition in Ready to Force Arm (Partition 1) [dsc1]
2019-11-13 19:33:47 - ISY Error: Web Error (FAILED) - NotFound (ns/1/nodes/n001_dsc1/report/status/GV1/09/70)
2019-11-13 19:33:55 - DSC TCP: Polling DSC [dsc1]
2019-11-13 19:33:55 - DSC: 50000025[C][L] [dsc1]
2019-11-13 19:33:55 - DSC: 500 - Command Acknowledge (000) [dsc1]
2019-11-13 19:34:21 - ISY Error: Web Error (FAILED) - NotFound (ns/1/nodes/n001_dsc1/report/status/GV1/09/70)
2019-11-13 19:34:47 - DSC: 60900130[C][L] [dsc1]
2019-11-13 19:34:47 - DSC: 609 - Zone Open (Zone 001) [dsc1]
2019-11-13 19:34:47 - DSC: Zone 1 (Door Akesis)  Opened [dsc1]
2019-11-13 19:34:47 - DSC: 51090FF[C][L] [dsc1]
2019-11-13 19:34:47 - DSC: 510 - Full LED Status Update [dsc1]
2019-11-13 19:34:47 - DSC: 6511CD[C][L] [dsc1]
2019-11-13 19:34:47 - DSC: 651 - Partition Not Ready (Partition 1) [dsc1]
2019-11-13 19:34:47 - DSC: System Status - Not Ready (Partition 1) [dsc1]
2019-11-13 19:34:51 - DSC: 61000128[C][L] [dsc1]
2019-11-13 19:34:51 - DSC: 610 - Zone Restored (Zone 001) [dsc1]
2019-11-13 19:34:51 - DSC: Zone 1 (Door Akesis)  Closed [dsc1]
2019-11-13 19:34:51 - DSC: 5109100[C][L] [dsc1]
2019-11-13 19:34:51 - DSC: 510 - Full LED Status Update [dsc1]
2019-11-13 19:34:51 - DSC: 6531CF[C][L] [dsc1]
2019-11-13 19:34:51 - DSC: 653 - Partition in Ready to Force Arm (Partition 1) [dsc1]
2019-11-13 19:34:55 - DSC TCP: Polling DSC [dsc1]
2019-11-13 19:34:55 - DSC: 50000025[C][L] [dsc1]
2019-11-13 19:34:55 - DSC: 500 - Command Acknowledge (000) [dsc1]
2019-11-13 19:34:55 - ISY Error: Web Error (FAILED) - NotFound (ns/1/nodes/n001_dsc1/report/status/GV1/09/70)
2019-11-13 19:35:29 - ISY Error: Web Error (FAILED) - NotFound (ns/1/nodes/n001_dsc1/report/status/GV1/09/70)
2019-11-13 19:35:55 - DSC TCP: Polling DSC [dsc1]
2019-11-13 19:35:55 - DSC: 50000025[C][L] [dsc1]
2019-11-13 19:35:55 - DSC: 500 - Command Acknowledge (000) [dsc1]
2019-11-13 19:36:03 - ISY Error: Web Error (FAILED) - NotFound (ns/1/nodes/n001_dsc1/report/status/GV1/09/70)
2019-11-13 19:36:37 - DSC: 60900130[C][L] [dsc1]
2019-11-13 19:36:37 - DSC: 609 - Zone Open (Zone 001) [dsc1]
2019-11-13 19:36:37 - DSC: Zone 1 (Door Akesis)  Opened [dsc1]
2019-11-13 19:36:37 - DSC: 51090FF[C][L] [dsc1]
2019-11-13 19:36:37 - DSC: 510 - Full LED Status Update [dsc1]
2019-11-13 19:36:37 - DSC: 6511CD[C][L] [dsc1]
2019-11-13 19:36:37 - DSC: 651 - Partition Not Ready (Partition 1) [dsc1]
2019-11-13 19:36:37 - DSC: System Status - Not Ready (Partition 1) [dsc1]
2019-11-13 19:36:37 - ISY Error: Web Error (FAILED) - NotFound (ns/1/nodes/n001_dsc1/report/status/GV1/09/70)
2019-11-13 19:36:42 - DSC: 61000128[C][L] [dsc1]
2019-11-13 19:36:42 - DSC: 610 - Zone Restored (Zone 001) [dsc1]
2019-11-13 19:36:42 - DSC: Zone 1 (Door Akesis)  Closed [dsc1]
2019-11-13 19:36:42 - DSC: 5109100[C][L] [dsc1]
2019-11-13 19:36:42 - DSC: 510 - Full LED Status Update [dsc1]
2019-11-13 19:36:42 - DSC: 6531CF[C][L] [dsc1]
2019-11-13 19:36:42 - DSC: 653 - Partition in Ready to Force Arm (Partition 1) [dsc1]
2019-11-13 19:36:55 - DSC TCP: Polling DSC [dsc1]
2019-11-13 19:36:55 - DSC: 50000025[C][L] [dsc1]
2019-11-13 19:36:55 - DSC: 500 - Command Acknowledge (000) [dsc1]
2019-11-13 19:37:04 - DSC: 51110F8[C][L] [dsc1]
2019-11-13 19:37:04 - DSC: 511 - Full LED Status (Flash) Update [dsc1]
2019-11-13 19:37:04 - DSC: 8490106[C][L] [dsc1]
2019-11-13 19:37:04 - DSC: 849 - Verbose Trouble Status Received [dsc1]
2019-11-13 19:37:04 - DSC: 51080FE[C][L]8402CE[C][L] [dsc1]
2019-11-13 19:37:04 - DSC: 510 - Full LED Status Update [dsc1]
2019-11-13 19:37:04 - DSC: 840 - Trouble Status (LED ON) (Partition 2) [dsc1]
2019-11-13 19:37:04 - DSC: Panel Trouble Present [dsc1]
2019-11-13 19:37:04 - DSC: 51100F7[C][L] [dsc1]
2019-11-13 19:37:04 - DSC: 5109100[C][L]8402CE[C][L] [dsc1]
2019-11-13 19:37:04 - DSC: 6531CF[C][L] [dsc1]
2019-11-13 19:37:04 - DSC: 653 - Partition in Ready to Force Arm (Partition 1) [dsc1]
2019-11-13 19:37:12 - ISY Error: Web Error (FAILED) - NotFound (ns/1/nodes/n001_dsc1/report/status/GV1/09/70)
2019-11-13 19:37:31 - DSC: 5109302[C][L] [dsc1]
2019-11-13 19:37:31 - DSC: 510 - Full LED Status Update [dsc1]
2019-11-13 19:37:31 - DSC: 6561D2[C][L] [dsc1]
2019-11-13 19:37:31 - DSC: 656 - Exit Delay in Progress (Partition 1) [dsc1]
2019-11-13 19:37:31 - DSC: System Status - Exit Delay In Progress (Partition 1) [dsc1]
2019-11-13 19:37:35 - DSC: 60900130[C][L] [dsc1]
2019-11-13 19:37:35 - DSC: 609 - Zone Open (Zone 001) [dsc1]
2019-11-13 19:37:35 - DSC: Zone 1 (Door Akesis)  Opened [dsc1]
2019-11-13 19:37:35 - DSC: 5109201[C][L] [dsc1]
2019-11-13 19:37:35 - DSC: 510 - Full LED Status Update [dsc1]
2019-11-13 19:37:39 - DSC: 61000128[C][L] [dsc1]
2019-11-13 19:37:39 - DSC: 610 - Zone Restored (Zone 001) [dsc1]
2019-11-13 19:37:39 - DSC: Zone 1 (Door Akesis)  Closed [dsc1]
2019-11-13 19:37:39 - DSC: 5109302[C][L] [dsc1]
2019-11-13 19:37:39 - DSC: 510 - Full LED Status Update [dsc1]
2019-11-13 19:37:46 - ISY Error: Web Error (FAILED) - NotFound (ns/1/nodes/n001_dsc1/report/status/GV1/09/70)
2019-11-13 19:37:55 - DSC TCP: Polling DSC [dsc1]
2019-11-13 19:37:55 - DSC: 50000025[C][L] [dsc1]
2019-11-13 19:37:55 - DSC: 500 - Command Acknowledge (000) [dsc1]
2019-11-13 19:38:20 - ISY Error: Web Error (FAILED) - NotFound (ns/1/nodes/n001_dsc1/report/status/GV1/09/70)
2019-11-13 19:38:55 - ISY Error: Web Error (FAILED) - NotFound (ns/1/nodes/n001_dsc1/report/status/GV1/09/70)
2019-11-13 19:38:55 - DSC TCP: Polling DSC [dsc1]
2019-11-13 19:38:55 - DSC: 50000025[C][L] [dsc1]
2019-11-13 19:38:55 - DSC: 500 - Command Acknowledge (000) [dsc1]
2019-11-13 19:39:29 - ISY Error: Web Error (FAILED) - NotFound (ns/1/nodes/n001_dsc1/report/status/GV1/09/70)
2019-11-13 19:39:30 - DSC: 5109201[C][L] [dsc1]
2019-11-13 19:39:30 - DSC: 510 - Full LED Status Update [dsc1]
2019-11-13 19:39:31 - DSC: 7001000991[C][L] [dsc1]
2019-11-13 19:39:31 - DSC: 700 - User Closing (Partition 1, User Code 0009) [dsc1]
2019-11-13 19:39:31 - DSC: 65210FE[C][L] [dsc1]
2019-11-13 19:39:31 - DSC: 652 - Partition Armed - Descriptive Mode (Partition 1, Mode Away) [dsc1]
2019-11-13 19:39:31 - DSC: System Status - Armed Away (Partition 1) [dsc1]
2019-11-13 19:39:55 - DSC TCP: Polling DSC [dsc1]
2019-11-13 19:39:55 - DSC: 50000025[C][L] [dsc1]
2019-11-13 19:39:55 - DSC: 500 - Command Acknowledge (000) [dsc1]
2019-11-13 19:40:03 - ISY Error: Web Error (FAILED) - NotFound (ns/1/nodes/n001_dsc1/report/status/GV1/09/70)
2019-11-13 19:40:37 - ISY Error: Web Error (FAILED) - NotFound (ns/1/nodes/n001_dsc1/report/status/GV1/09/70)
2019-11-13 19:40:55 - DSC TCP: Polling DSC [dsc1]
2019-11-13 19:40:55 - DSC: 50000025[C][L] [dsc1]
2019-11-13 19:40:55 - DSC: 500 - Command Acknowledge (000) [dsc1]
2019-11-13 19:41:11 - ISY Error: Web Error (FAILED) - NotFound (ns/1/nodes/n001_dsc1/report/status/GV1/09/70)
2019-11-13 19:41:14 - DSC: 51110F8[C][L] [dsc1]
2019-11-13 19:41:14 - DSC: 511 - Full LED Status (Flash) Update [dsc1]
2019-11-13 19:41:14 - DSC: 8490106[C][L] [dsc1]
2019-11-13 19:41:14 - DSC: 849 - Verbose Trouble Status Received [dsc1]
2019-11-13 19:41:14 - DSC: 51080FE[C][L]8402CE[C][L] [dsc1]
2019-11-13 19:41:14 - DSC: 510 - Full LED Status Update [dsc1]
2019-11-13 19:41:14 - DSC: 840 - Trouble Status (LED ON) (Partition 2) [dsc1]
2019-11-13 19:41:14 - DSC: Panel Trouble Present [dsc1]
2019-11-13 19:41:14 - DSC: 51100F7[C][L] [dsc1]
2019-11-13 19:41:14 - DSC: 5109201[C][L]8402CE[C][L] [dsc1]
2019-11-13 19:41:14 - DSC: 65210FE[C][L] [dsc1]
2019-11-13 19:41:14 - DSC: 652 - Partition Armed - Descriptive Mode (Partition 1, Mode Away) [dsc1]
2019-11-13 19:41:14 - DSC: System Status - Armed Away (Partition 1) [dsc1]
2019-11-13 19:41:44 - ISY Error: Web Error (FAILED) - NotFound (ns/1/nodes/n001_dsc1/report/status/GV1/09/70)
2019-11-13 19:41:55 - DSC TCP: Polling DSC [dsc1]
2019-11-13 19:41:55 - DSC: 50000025[C][L] [dsc1]
2019-11-13 19:41:55 - DSC: 500 - Command Acknowledge (000) [dsc1]
2019-11-13 19:42:18 - ISY Error: Web Error (FAILED) - NotFound (ns/1/nodes/n001_dsc1/report/status/GV1/09/70)
2019-11-13 19:42:51 - ISY Error: Web Error (FAILED) - NotFound (ns/1/nodes/n001_dsc1/report/status/GV1/09/70)
2019-11-13 19:42:55 - DSC TCP: Polling DSC [dsc1]
2019-11-13 19:42:55 - DSC: 50000025[C][L] [dsc1]
2019-11-13 19:42:55 - DSC: 500 - Command Acknowledge (000) [dsc1]
Restarted nodelink which seems to have corrected the current situation.  I also noticed another 404 error.
2019-11-13 20:17:45 - ISY NodeLink Server v0.10.2 started
2019-11-13 20:17:45 - OS: Microsoft Windows NT 6.2.9200.0
2019-11-13 20:17:45 - Web config server started (http://192.168.1.71:8090)
2019-11-13 20:17:47 - ISY resolved to 192.168.1.9 (5.0.16)
2019-11-13 20:17:47 - ISY Node Server config detected (profile 1)
2019-11-13 20:17:47 - Auto-Update: Error updating file: The remote server returned an error: (404) Not Found.
2019-11-13 20:17:48 - ISY Warning: Duplicate node names exist on the ISY (Door Cadiz)
2019-11-13 20:17:48 - ISY Warning: Duplicate node names exist on the ISY (Motion Back)
2019-11-13 20:17:48 - ISY Warning: Duplicate node names exist on the ISY (Doorbell Akesis)
2019-11-13 20:17:48 - ISY Warning: Duplicate node names exist on the ISY (Door Akesis)
2019-11-13 20:17:48 - ISY Warning: Duplicate node names exist on the ISY (Motion Front)
2019-11-13 20:17:48 - ISY Warning: Duplicate node names exist on the ISY (Doorbell Fire Escape)
2019-11-13 20:17:48 - ISY Warning: Duplicate node names exist on the ISY (Ellens S8)
2019-11-13 20:17:48 - ISY Warning: Duplicate node names exist on the ISY (Door Kitchen to Cadiz)
2019-11-13 20:17:48 - ISY Warning: Duplicate node names exist on the ISY (Lous S8)
2019-11-13 20:17:48 - ISY Warning: Duplicate node names exist on the ISY (Door Front)
2019-11-13 20:17:48 - ISY Warning: Duplicate node names exist on the ISY (Door Fire Escape)
2019-11-13 20:17:49 - DSC: Connected to 192.168.2.141 [dsc1]
2019-11-13 20:17:49 - DSC: 5053CD[C][L] [dsc1]
2019-11-13 20:17:49 - DSC: 505 - Login Interaction (Password Requested) [dsc1]
2019-11-13 20:17:49 - DSC: EVL User Login - Password Sent [dsc1]
2019-11-13 20:17:49 - DSC: 5000052A[C][L]5051CB[C][L] [dsc1]
2019-11-13 20:17:49 - DSC: 500 - Command Acknowledge (005) [dsc1]
2019-11-13 20:17:49 - DSC: 505 - Login Interaction (Password Correct, Session Established) [dsc1]
2019-11-13 20:17:49 - DSC: Status Request Sent [dsc1]
2019-11-13 20:17:49 - DSC: Data Sent - 00191 [dsc1]
2019-11-13 20:17:49 - DSC TCP: Polling DSC [dsc1]
2019-11-13 20:17:49 - DSC: 50000126[C][L]61000128[C][L]60900231[C][L]6100032A[C][L]6100042B[C][L]6100052C[C][L]6100062D[C][L]60900736[C][L]6100082F[C][L]61000930[C][L]61001028[C][L]61001129[C][L]6100122A[C][L]6100132B[C][L]6100142C[C][L]6100152D[C][L]6100162E[C][L]6100172F[C][L]61001830[C][L]61001931[C][L]61002029[C][L]6100212A[C][L]6100222B[C][L]6100232C[C][L] [dsc1]
2019-11-13 20:17:49 - DSC: 500 - Command Acknowledge (001) [dsc1]
2019-11-13 20:17:49 - DSC: 610 - Zone Restored (Zone 001) [dsc1]
2019-11-13 20:17:49 - DSC: Zone 1 (Door Akesis)  Closed [dsc1]
2019-11-13 20:17:49 - DSC: 609 - Zone Open (Zone 002) [dsc1]
2019-11-13 20:17:49 - DSC: Zone 2 (Doorbell Akesis)  Opened [dsc1]
2019-11-13 20:17:49 - DSC: 610 - Zone Restored (Zone 003) [dsc1]
2019-11-13 20:17:49 - DSC: Zone 3 (Door Front)  Closed [dsc1]
2019-11-13 20:17:49 - DSC: 610 - Zone Restored (Zone 004) [dsc1]
2019-11-13 20:17:49 - DSC: Zone 4 (Door Cadiz)  Closed [dsc1]
2019-11-13 20:17:49 - DSC: 610 - Zone Restored (Zone 005) [dsc1]
2019-11-13 20:17:49 - DSC: Zone 5 (Door Fire Escape)  Closed [dsc1]
2019-11-13 20:17:49 - DSC: 610 - Zone Restored (Zone 006) [dsc1]
2019-11-13 20:17:49 - DSC: Zone 6 (Motion Front)  Closed [dsc1]
2019-11-13 20:17:49 - DSC: 609 - Zone Open (Zone 007) [dsc1]
2019-11-13 20:17:49 - DSC: Zone 7 (Doorbell Fire Escape)  Opened [dsc1]
2019-11-13 20:17:49 - DSC: 610 - Zone Restored (Zone 008) [dsc1]
2019-11-13 20:17:49 - DSC: Zone 8 (Motion Back)  Closed [dsc1]
2019-11-13 20:17:49 - DSC: 610 - Zone Restored (Zone 009) [dsc1]
2019-11-13 20:17:49 - DSC: Zone 9 (Door Kitchen to Cadiz)  Closed [dsc1]
2019-11-13 20:17:49 - DSC: 610 - Zone Restored (Zone 010) [dsc1]
2019-11-13 20:17:49 - DSC: 610 - Zone Restored (Zone 011) [dsc1]
2019-11-13 20:17:49 - DSC: 610 - Zone Restored (Zone 012) [dsc1]
2019-11-13 20:17:49 - DSC: 610 - Zone Restored (Zone 013) [dsc1]
2019-11-13 20:17:49 - DSC: 610 - Zone Restored (Zone 014) [dsc1]
2019-11-13 20:17:49 - DSC: 610 - Zone Restored (Zone 015) [dsc1]
2019-11-13 20:17:49 - DSC: 610 - Zone Restored (Zone 016) [dsc1]
2019-11-13 20:17:49 - DSC: 610 - Zone Restored (Zone 017) [dsc1]
2019-11-13 20:17:49 - DSC: 610 - Zone Restored (Zone 018) [dsc1]
2019-11-13 20:17:49 - DSC: 610 - Zone Restored (Zone 019) [dsc1]
2019-11-13 20:17:49 - DSC: 610 - Zone Restored (Zone 020) [dsc1]
2019-11-13 20:17:49 - DSC: 610 - Zone Restored (Zone 021) [dsc1]
2019-11-13 20:17:49 - DSC: 610 - Zone Restored (Zone 022) [dsc1]
2019-11-13 20:17:49 - DSC: 610 - Zone Restored (Zone 023) [dsc1]
2019-11-13 20:17:49 - DSC: 50000025[C][L] [dsc1]
2019-11-13 20:17:49 - DSC: 500 - Command Acknowledge (000) [dsc1]
2019-11-13 20:17:50 - DSC: 6100242D[C][L]6100252E[C][L]6100262F[C][L]61002730[C][L]61002831[C][L]61002932[C][L]6100302A[C][L]6100312B[C][L]6100322C[C][L]6100332D[C][L]6100342E[C][L]6100352F[C][L]61003630[C][L]61003731[C][L]61003832[C][L]61003933[C][L]6100402B[C][L]6100412C[C][L]6100422D[C][L]6100432E[C][L]6100442F[C][L]61004530[C][L]61004631[C][L]61004732[C][L] [dsc1]
2019-11-13 20:17:50 - DSC: 610 - Zone Restored (Zone 024) [dsc1]
2019-11-13 20:17:50 - DSC: 610 - Zone Restored (Zone 025) [dsc1]
2019-11-13 20:17:50 - DSC: 610 - Zone Restored (Zone 026) [dsc1]
2019-11-13 20:17:50 - DSC: 610 - Zone Restored (Zone 027) [dsc1]
2019-11-13 20:17:50 - DSC: 610 - Zone Restored (Zone 028) [dsc1]
2019-11-13 20:17:50 - DSC: 610 - Zone Restored (Zone 029) [dsc1]
2019-11-13 20:17:50 - DSC: 610 - Zone Restored (Zone 030) [dsc1]
2019-11-13 20:17:50 - DSC: 610 - Zone Restored (Zone 031) [dsc1]
2019-11-13 20:17:50 - DSC: 610 - Zone Restored (Zone 032) [dsc1]
2019-11-13 20:17:50 - DSC: 610 - Zone Restored (Zone 033) [dsc1]
2019-11-13 20:17:50 - DSC: 610 - Zone Restored (Zone 034) [dsc1]
2019-11-13 20:17:50 - DSC: 610 - Zone Restored (Zone 035) [dsc1]
2019-11-13 20:17:50 - DSC: 610 - Zone Restored (Zone 036) [dsc1]
2019-11-13 20:17:50 - DSC: 610 - Zone Restored (Zone 037) [dsc1]
2019-11-13 20:17:50 - DSC: 610 - Zone Restored (Zone 038) [dsc1]
2019-11-13 20:17:50 - DSC: 610 - Zone Restored (Zone 039) [dsc1]
2019-11-13 20:17:50 - DSC: 610 - Zone Restored (Zone 040) [dsc1]
2019-11-13 20:17:50 - DSC: 610 - Zone Restored (Zone 041) [dsc1]
2019-11-13 20:17:50 - DSC: 610 - Zone Restored (Zone 042) [dsc1]
2019-11-13 20:17:50 - DSC: 610 - Zone Restored (Zone 043) [dsc1]
2019-11-13 20:17:50 - DSC: 610 - Zone Restored (Zone 044) [dsc1]
2019-11-13 20:17:50 - DSC: 610 - Zone Restored (Zone 045) [dsc1]
2019-11-13 20:17:50 - DSC: 610 - Zone Restored (Zone 046) [dsc1]
2019-11-13 20:17:50 - DSC: 610 - Zone Restored (Zone 047) [dsc1]
2019-11-13 20:17:51 - DSC: 61004833[C][L]61004934[C][L]6100502C[C][L]6100512D[C][L]6100522E[C][L]6100532F[C][L]61005430[C][L]61005531[C][L]61005632[C][L]61005733[C][L]61005834[C][L]61005935[C][L]6100602D[C][L]6100612E[C][L]6100622F[C][L]61006330[C][L]61006431[C][L]65210FE[C][L]6502CD[C][L]6733D3[C][L]6734D4[C][L]6735D5[C][L]6736D6[C][L]6737D7[C][L]6738D8[C][L]8401CD[C][L] [dsc1]
2019-11-13 20:17:51 - DSC: 610 - Zone Restored (Zone 048) [dsc1]
2019-11-13 20:17:51 - DSC: 610 - Zone Restored (Zone 049) [dsc1]
2019-11-13 20:17:51 - DSC: 610 - Zone Restored (Zone 050) [dsc1]
2019-11-13 20:17:51 - DSC: 610 - Zone Restored (Zone 051) [dsc1]
2019-11-13 20:17:51 - DSC: 610 - Zone Restored (Zone 052) [dsc1]
2019-11-13 20:17:51 - DSC: 610 - Zone Restored (Zone 053) [dsc1]
2019-11-13 20:17:51 - DSC: 610 - Zone Restored (Zone 054) [dsc1]
2019-11-13 20:17:51 - DSC: 610 - Zone Restored (Zone 055) [dsc1]
2019-11-13 20:17:51 - DSC: 610 - Zone Restored (Zone 056) [dsc1]
2019-11-13 20:17:51 - DSC: 610 - Zone Restored (Zone 057) [dsc1]
2019-11-13 20:17:51 - DSC: 610 - Zone Restored (Zone 058) [dsc1]
2019-11-13 20:17:51 - DSC: 610 - Zone Restored (Zone 059) [dsc1]
2019-11-13 20:17:51 - DSC: 610 - Zone Restored (Zone 060) [dsc1]
2019-11-13 20:17:51 - DSC: 610 - Zone Restored (Zone 061) [dsc1]
2019-11-13 20:17:51 - DSC: 610 - Zone Restored (Zone 062) [dsc1]
2019-11-13 20:17:51 - DSC: 610 - Zone Restored (Zone 063) [dsc1]
2019-11-13 20:17:51 - DSC: 610 - Zone Restored (Zone 064) [dsc1]
2019-11-13 20:17:51 - DSC: 652 - Partition Armed - Descriptive Mode (Partition 1, Mode Away) [dsc1]
2019-11-13 20:17:51 - DSC: System Status - Armed Away (Partition 1) [dsc1]
2019-11-13 20:17:51 - DSC: 650 - Partition Ready (Partition 2) [dsc1]
2019-11-13 20:17:51 - DSC: System Status - Ready (Partition 2) [dsc1]
2019-11-13 20:17:51 - DSC: System Status - Disarmed (Set By Status Request - Partition 2) [dsc1]
2019-11-13 20:17:51 - DSC: 673 - Partition Busy (Partition 3) [dsc1]
2019-11-13 20:17:51 - DSC: 673 - Partition Busy (Partition 4) [dsc1]
2019-11-13 20:17:51 - DSC: 673 - Partition Busy (Partition 5) [dsc1]
2019-11-13 20:17:51 - DSC: 673 - Partition Busy (Partition 6) [dsc1]
2019-11-13 20:17:51 - DSC: 673 - Partition Busy (Partition 7) [dsc1]
2019-11-13 20:17:51 - DSC: 673 - Partition Busy (Partition 8) [dsc1]
2019-11-13 20:17:51 - DSC: 840 - Trouble Status (LED ON) (Partition 1) [dsc1]
2019-11-13 20:17:51 - DSC: Panel Trouble Present [dsc1]
2019-11-13 20:17:52 - DSC: 8402CE[C][L]8403CF[C][L]8404D0[C][L]8405D1[C][L]8406D2[C][L]8407D3[C][L]8408D4[C][L]5109201[C][L] [dsc1]
2019-11-13 20:17:52 - DSC: 840 - Trouble Status (LED ON) (Partition 2) [dsc1]
2019-11-13 20:17:52 - DSC: Panel Trouble Present [dsc1]
2019-11-13 20:17:52 - DSC: 840 - Trouble Status (LED ON) (Partition 3) [dsc1]
2019-11-13 20:17:52 - DSC: 840 - Trouble Status (LED ON) (Partition 4) [dsc1]
2019-11-13 20:17:52 - DSC: 840 - Trouble Status (LED ON) (Partition 5) [dsc1]
2019-11-13 20:17:52 - DSC: 840 - Trouble Status (LED ON) (Partition 6) [dsc1]
2019-11-13 20:17:52 - DSC: 840 - Trouble Status (LED ON) (Partition 7) [dsc1]
2019-11-13 20:17:52 - DSC: 840 - Trouble Status (LED ON) (Partition 8) [dsc1]
2019-11-13 20:17:52 - DSC: 510 - Full LED Status Update [dsc1]
2019-11-13 20:18:44 - DSC: 51110F8[C][L] [dsc1]
2019-11-13 20:18:44 - DSC: 511 - Full LED Status (Flash) Update [dsc1]
2019-11-13 20:18:44 - DSC: 8490106[C][L] [dsc1]
2019-11-13 20:18:44 - DSC: 849 - Verbose Trouble Status Received [dsc1]
2019-11-13 20:18:44 - DSC: 51080FE[C][L]8402CE[C][L] [dsc1]
2019-11-13 20:18:44 - DSC: 510 - Full LED Status Update [dsc1]
2019-11-13 20:18:44 - DSC: 840 - Trouble Status (LED ON) (Partition 2) [dsc1]
2019-11-13 20:18:44 - DSC: Panel Trouble Present [dsc1]
2019-11-13 20:18:44 - DSC: 51100F7[C][L] [dsc1]
2019-11-13 20:18:44 - DSC: 5109201[C][L]8402CE[C][L] [dsc1]
2019-11-13 20:18:45 - DSC: 65210FE[C][L] [dsc1]
2019-11-13 20:18:45 - DSC: 652 - Partition Armed - Descriptive Mode (Partition 1, Mode Away) [dsc1]
2019-11-13 20:18:45 - DSC: System Status - Armed Away (Partition 1) [dsc1]
2019-11-13 20:18:49 - DSC TCP: Polling DSC [dsc1]
2019-11-13 20:18:49 - DSC: 50000025[C][L] [dsc1]
2019-11-13 20:18:49 - DSC: 500 - Command Acknowledge (000) [dsc1]
The error in your first log was some sort of network issue.  NodeLink failed to write to the ISY so it continually retries every 30s.  It could never update the ISY.
I don't see anything in your log for the command output.  Should see either a 660 or a 912.
I don't really understand that since I didn't have any network issue.  I was using the ISY admin console from that same computer while the error was accumulating.  Whatever comm issue was happening had to be specific to nodelink.  Fixing the problem only required restarting nodelink, nothing else.  ISY and that computer are both hard wired to the same LAN.  Anyway, I will see what happens tonight when I arm the system and the output turns on.  Unfortunately I missed this morning when it turned off.  I didn't realize the web page only holds a couple hours worth of log events and I didn't have the logging to file set to debug level.
@io_guy
2019-11-14 16:09:49 - DSC: 500 - Command Acknowledge (000) [dsc1]
2019-11-14 16:10:45 - DSC: 5108301[C][L] [dsc1]
2019-11-14 16:10:45 - DSC: 510 - Full LED Status Update [dsc1]
2019-11-14 16:10:45 - DSC: 6561D2[C][L] [dsc1]
2019-11-14 16:10:45 - DSC: 656 - Exit Delay in Progress (Partition 1) [dsc1]
2019-11-14 16:10:45 - DSC: System Status - Exit Delay In Progress (Partition 1) [dsc1]
2019-11-14 16:10:49 - DSC TCP: Polling DSC [dsc1]
2019-11-14 16:10:49 - DSC: 50000025[C][L] [dsc1]
2019-11-14 16:10:49 - DSC: 500 - Command Acknowledge (000) [dsc1]
2019-11-14 16:10:51 - DSC: 51081FF[C][L] [dsc1]
2019-11-14 16:10:51 - DSC: 510 - Full LED Status Update [dsc1]
2019-11-14 16:10:51 - DSC: 6551D1[C][L] [dsc1]
2019-11-14 16:10:51 - DSC: 655 - Partition Disarmed (Partition 1) [dsc1]
2019-11-14 16:10:51 - DSC: System Status - Disarmed (Partition 1) [dsc1]
2019-11-14 16:10:54 - DSC: 6531CF[C][L] [dsc1]
2019-11-14 16:10:54 - DSC: 653 - Partition in Ready to Force Arm (Partition 1) [dsc1]
I just armed and disarmed.  Output 1 actually turned on immediately upon arming (exit delay) then off immediately upon entering the disarming code.  In other words, the water valve actually turned off then on which can only happen if the output turned on then off.  I don't see anything here that says that.  But some of the lines in here I don't know what the codes mean.  I don't know if this means that the panel simply isn't communicating this fact or what.  As I mentioned, the output is set within the DSC programming to turn on upon arming of both partitions and off when either partition is disarmed.
EDIT:  Also just noticed that it says the disarming user is the same person who did it this morning.  It still says user 4 disarmed (the morning person), but it was me (user 40).  Perhaps it has something to do with the fact that it never actually armed but rather was shut down while in exit delay.
EDIT AGAIN:  Below is another arming of the system.
2019-11-14 16:54:49 - DSC: 500 - Command Acknowledge (000) [dsc1]
2019-11-14 16:55:49 - DSC TCP: Polling DSC [dsc1]
2019-11-14 16:55:49 - DSC: 50000025[C][L] [dsc1]
2019-11-14 16:55:49 - DSC: 500 - Command Acknowledge (000) [dsc1]
2019-11-14 16:56:49 - DSC TCP: Polling DSC [dsc1]
2019-11-14 16:56:49 - DSC: 50000025[C][L] [dsc1]
2019-11-14 16:56:49 - DSC: 500 - Command Acknowledge (000) [dsc1]
2019-11-14 16:57:47 - DSC: 5108301[C][L] [dsc1]
2019-11-14 16:57:47 - DSC: 510 - Full LED Status Update [dsc1]
2019-11-14 16:57:48 - DSC: 6561D2[C][L] [dsc1]
2019-11-14 16:57:48 - DSC: 656 - Exit Delay in Progress (Partition 1) [dsc1]
2019-11-14 16:57:48 - DSC: System Status - Exit Delay In Progress (Partition 1) [dsc1]
2019-11-14 16:57:49 - DSC TCP: Polling DSC [dsc1]
2019-11-14 16:57:49 - DSC: 50000025[C][L] [dsc1]
2019-11-14 16:57:49 - DSC: 500 - Command Acknowledge (000) [dsc1]
2019-11-14 16:57:53 - DSC: 60900130[C][L] [dsc1]
2019-11-14 16:57:53 - DSC: 609 - Zone Open (Zone 001) [dsc1]
2019-11-14 16:57:53 - DSC: Zone 1 (Door Akesis)  Opened [dsc1]
2019-11-14 16:57:53 - DSC: 5108200[C][L] [dsc1]
2019-11-14 16:57:53 - DSC: 510 - Full LED Status Update [dsc1]
2019-11-14 16:57:56 - DSC: 61000128[C][L] [dsc1]
2019-11-14 16:57:56 - DSC: 610 - Zone Restored (Zone 001) [dsc1]
2019-11-14 16:57:56 - DSC: Zone 1 (Door Akesis)  Closed [dsc1]
2019-11-14 16:57:56 - DSC: 5108301[C][L] [dsc1]
2019-11-14 16:57:56 - DSC: 510 - Full LED Status Update [dsc1]
2019-11-14 16:58:49 - DSC TCP: Polling DSC [dsc1]
2019-11-14 16:58:49 - DSC: 50000025[C][L] [dsc1]
2019-11-14 16:58:49 - DSC: 500 - Command Acknowledge (000) [dsc1]
2019-11-14 16:59:47 - DSC: 5108200[C][L] [dsc1]
2019-11-14 16:59:47 - DSC: 510 - Full LED Status Update [dsc1]
2019-11-14 16:59:47 - DSC: 7001000890[C][L] [dsc1]
2019-11-14 16:59:47 - DSC: 700 - User Closing (Partition 1, User Code 0008) [dsc1]
2019-11-14 16:59:47 - DSC: 65210FE[C][L] [dsc1]
2019-11-14 16:59:47 - DSC: 652 - Partition Armed - Descriptive Mode (Partition 1, Mode Away) [dsc1]
2019-11-14 16:59:47 - DSC: System Status - Armed Away (Partition 1) [dsc1]
2019-11-14 16:59:49 - DSC TCP: Polling DSC [dsc1]
2019-11-14 16:59:49 - DSC: 50000025[C][L] [dsc1]
2019-11-14 16:59:49 - DSC: 500 - Command Acknowledge (000) [dsc1]
2019-11-14 17:00:49 - DSC TCP: Polling DSC [dsc1]
2019-11-14 17:00:49 - DSC: 50000025[C][L] [dsc1]
2019-11-14 17:00:49 - DSC: 500 - Command Acknowledge (000) [dsc1]
2019-11-14 17:01:49 - DSC TCP: Polling DSC [dsc1]
2019-11-14 17:01:49 - DSC: 50000025[C][L] [dsc1]
2019-11-14 17:01:49 - DSC: 500 - Command Acknowledge (000) [dsc1]
2019-11-14 17:02:49 - DSC TCP: Polling DSC [dsc1]
2019-11-14 17:02:49 - DSC: 50000025[C][L] [dsc1]
2019-11-14 17:02:49 - DSC: 500 - Command Acknowledge (000) [dsc1]
2019-11-14 17:03:49 - DSC TCP: Polling DSC [dsc1]
2019-11-14 17:03:49 - DSC: 50000025[C][L] [dsc1]
2019-11-14 17:03:49 - DSC: 500 - Command Acknowledge (000) [dsc1]
2019-11-14 17:04:49 - DSC TCP: Polling DSC [dsc1]
2019-11-14 17:04:49 - DSC: 50000025[C][L] [dsc1]
2019-11-14 17:04:49 - DSC: 500 - Command Acknowledge (000) [dsc1]
2019-11-14 17:05:49 - DSC TCP: Polling DSC [dsc1]
2019-11-14 17:05:49 - DSC: 50000025[C][L] [dsc1]
2019-11-14 17:05:49 - DSC: 500 - Command Acknowledge (000) [dsc1]
2019-11-14 17:06:49 - DSC TCP: Polling DSC [dsc1]
2019-11-14 17:06:49 - DSC: 50000025[C][L] [dsc1]
2019-11-14 17:06:49 - DSC: 500 - Command Acknowledge (000) [dsc1]
2019-11-14 17:07:49 - DSC TCP: Polling DSC [dsc1]
2019-11-14 17:07:49 - DSC: 50000025[C][L] [dsc1]
2019-11-14 17:07:49 - DSC: 500 - Command Acknowledge (000) [dsc1]
2019-11-14 17:08:49 - DSC TCP: Polling DSC [dsc1]
2019-11-14 17:08:49 - DSC: 50000025[C][L] [dsc1]
2019-11-14 17:08:49 - DSC: 500 - Command Acknowledge (000) [dsc1]
2019-11-14 17:09:49 - DSC TCP: Polling DSC [dsc1]
2019-11-14 17:09:49 - DSC: 50000025[C][L] [dsc1]
2019-11-14 17:09:49 - DSC: 500 - Command Acknowledge (000) [dsc1]
2019-11-14 17:10:49 - DSC TCP: Polling DSC [dsc1]
2019-11-14 17:10:49 - DSC: 50000025[C][L] [dsc1]
2019-11-14 17:10:49 - DSC: 500 - Command Acknowledge (000) [dsc1]
Yea nothing in there for PGM output.   It must only trigger the API when the keypad is manually pressed to turn a PGM on.
Unrelated, but I'm getting 404 errors in the log when it looks for updates.
See the post below. If you tried the earliest release of nodelink 10, there's a "catch 22" because it doesn't have the ability to reach io_guy's server and it never auto-updates. A one time manual upgrade to .3 fixes it for good. You can tell this is the issue if your nodelink page stills shows 10.0
You can get the file here: http://automationshack.com/Files/NodeLink.dll
Edited by paulbates
I was getting the error on 0.10.2.  Some of the logs above I think include the boot-up sequence and the 404 error.  I went ahead and manually updated to 0.10.3.  Going to .0.10 in general required a bit of a contortion act since it wants admin priv.  I had to create a scheduled task in order to have it automatically run at startup.  Also had to install the latest ,net stuff.
If it's a Pi you could just use the install script
@io_guy
EDIT LAST ONE: I keep playing with this.  The terminology "command output" is what DSC uses to describe hitting *71 or *72 or etc.  This does not appear to be a state, it appears to be an event, like an insteon "switched on" event, rather than "status on".
I've been playing with the outputs.  I don't think DSC really works like you have it setup in NL.  It appears that what you are showing as status of output is just that an output trigger was keyed in to a keypad.  For example, *72 triggers output 2 on if you have it set that way.  It can either be for a period of time, or it can be latching/toggle.  I tried both ways.  As soon as I key in *72, the output turns "on" in the NL gui on ISY.  But it does not turn off again after the 2 second delay that is default.  Converting to latching mode, each time I toggle it (by hitting *72), it just sends another "activated" signal to NL.  So, it looks like, once that flag is set to "on" in ISY, it never turns off short of a restart of NL.  If you go through the log, you will see every time I hit *72.  It gives the same response regardless of whether it was turning the output on or off.
Also, would it be possible to include a *71/*72/etc node. for triggering the outputs from ISY/NL?
EDIT: OK, now at some point the output went back to "off".  I don't know why or when exactly.  I'll add the rest of the log.  But it does not change to "off" simultaneous to actually turning it off.  Is there some sort of time out?
EDIT AGAIN:  Don't know how the ISY pgm state switched to "off" last time, but I toggled it on and then off again, and it has been about 40 minutes and ISY still says "on".
2019-11-15 13:29:13 - DSC: 841 - Trouble Status Restore (LED OFF) (Partition 1) [dsc1]
2019-11-15 13:29:13 - DSC: Panel OK [dsc1]
2019-11-15 13:29:13 - DSC: 841 - Trouble Status Restore (LED OFF) (Partition 2) [dsc1]
2019-11-15 13:29:13 - DSC: 841 - Trouble Status Restore (LED OFF) (Partition 3) [dsc1]
2019-11-15 13:29:13 - DSC: 841 - Trouble Status Restore (LED OFF) (Partition 4) [dsc1]
2019-11-15 13:29:13 - DSC: 841 - Trouble Status Restore (LED OFF) (Partition 5) [dsc1]
2019-11-15 13:29:13 - DSC: 8416D3[C][L]8417D4[C][L]8418D5[C][L]51081FF[C][L] [dsc1]
2019-11-15 13:29:13 - DSC: 841 - Trouble Status Restore (LED OFF) (Partition 6) [dsc1]
2019-11-15 13:29:13 - DSC: 841 - Trouble Status Restore (LED OFF) (Partition 7) [dsc1]
2019-11-15 13:29:13 - DSC: 841 - Trouble Status Restore (LED OFF) (Partition 8) [dsc1]
2019-11-15 13:29:13 - DSC: 510 - Full LED Status Update [dsc1]
2019-11-15 13:30:11 - DSC TCP: Polling DSC [dsc1]
2019-11-15 13:30:11 - DSC: 50000025[C][L] [dsc1]
2019-11-15 13:30:11 - DSC: 500 - Command Acknowledge (000) [dsc1]
2019-11-15 13:31:11 - DSC TCP: Polling DSC [dsc1]
2019-11-15 13:31:13 - DSC: 50000025[C][L] [dsc1]
2019-11-15 13:31:13 - DSC: 500 - Command Acknowledge (000) [dsc1]
2019-11-15 13:32:11 - DSC TCP: Polling DSC [dsc1]
2019-11-15 13:32:11 - DSC: 50000025[C][L] [dsc1]
2019-11-15 13:32:11 - DSC: 500 - Command Acknowledge (000) [dsc1]
2019-11-15 13:32:19 - DSC: 51080FE[C][L] [dsc1]
2019-11-15 13:32:19 - DSC: 510 - Full LED Status Update [dsc1]
2019-11-15 13:32:20 - DSC: 51081FF[C][L] [dsc1]
2019-11-15 13:32:20 - DSC: 510 - Full LED Status Update [dsc1]
2019-11-15 13:32:20 - DSC: 91212FF[C][L] [dsc1]
2019-11-15 13:32:20 - DSC: 912 - Command Output Pressed (Partition 1, Output 2) [dsc1]
2019-11-15 13:32:20 - DSC: Command Output 2 Triggered [dsc1]
2019-11-15 13:32:21 - DSC: 6601CD[C][L] [dsc1]
2019-11-15 13:32:21 - DSC: 660 - Command Output in Progress (Partition 1) [dsc1]
2019-11-15 13:32:26 - DSC: 6531CF[C][L] [dsc1]
2019-11-15 13:32:26 - DSC: 653 - Partition in Ready to Force Arm (Partition 1) [dsc1]
2019-11-15 13:33:06 - DSC: 51080FE[C][L] [dsc1]
2019-11-15 13:33:06 - DSC: 510 - Full LED Status Update [dsc1]
2019-11-15 13:33:07 - DSC: 51081FF[C][L] [dsc1]
2019-11-15 13:33:07 - DSC: 510 - Full LED Status Update [dsc1]
2019-11-15 13:33:07 - DSC: 91212FF[C][L] [dsc1]
2019-11-15 13:33:07 - DSC: 912 - Command Output Pressed (Partition 1, Output 2) [dsc1]
2019-11-15 13:33:07 - DSC: Command Output 2 Triggered [dsc1]
2019-11-15 13:33:07 - DSC: 6601CD[C][L] [dsc1]
2019-11-15 13:33:07 - DSC: 660 - Command Output in Progress (Partition 1) [dsc1]
2019-11-15 13:33:11 - DSC TCP: Polling DSC [dsc1]
2019-11-15 13:33:11 - DSC: 50000025[C][L] [dsc1]
2019-11-15 13:33:11 - DSC: 500 - Command Acknowledge (000) [dsc1]
2019-11-15 13:33:13 - DSC: 6531CF[C][L] [dsc1]
2019-11-15 13:33:13 - DSC: 653 - Partition in Ready to Force Arm (Partition 1) [dsc1]
2019-11-15 13:33:42 - DSC: 6735D5[C][L]6736D6[C][L]6737D7[C][L]6738D8[C][L] [dsc1]
2019-11-15 13:33:42 - DSC: 673 - Partition Busy (Partition 5) [dsc1]
2019-11-15 13:33:42 - DSC: 673 - Partition Busy (Partition 6) [dsc1]
2019-11-15 13:33:42 - DSC: 673 - Partition Busy (Partition 7) [dsc1]
2019-11-15 13:33:42 - DSC: 673 - Partition Busy (Partition 8) [dsc1]
2019-11-15 13:34:11 - DSC TCP: Polling DSC [dsc1]
2019-11-15 13:34:11 - DSC: 50000025[C][L] [dsc1]
2019-11-15 13:34:11 - DSC: 500 - Command Acknowledge (000) [dsc1]
2019-11-15 13:35:11 - DSC TCP: Polling DSC [dsc1]
2019-11-15 13:35:11 - DSC: 50000025[C][L] [dsc1]
2019-11-15 13:35:11 - DSC: 500 - Command Acknowledge (000) [dsc1]
2019-11-15 13:36:11 - DSC TCP: Polling DSC [dsc1]
2019-11-15 13:36:11 - DSC: 50000025[C][L] [dsc1]
2019-11-15 13:36:11 - DSC: 500 - Command Acknowledge (000) [dsc1]
2019-11-15 13:37:11 - DSC TCP: Polling DSC [dsc1]
2019-11-15 13:37:11 - DSC: 50000025[C][L] [dsc1]
2019-11-15 13:37:11 - DSC: 500 - Command Acknowledge (000) [dsc1]
2019-11-15 13:38:11 - DSC TCP: Polling DSC [dsc1]
2019-11-15 13:38:11 - DSC: 50000025[C][L] [dsc1]
2019-11-15 13:38:11 - DSC: 500 - Command Acknowledge (000) [dsc1]
2019-11-15 13:39:11 - DSC TCP: Polling DSC [dsc1]
2019-11-15 13:39:11 - DSC: 50000025[C][L] [dsc1]
2019-11-15 13:39:11 - DSC: 500 - Command Acknowledge (000) [dsc1]
2019-11-15 13:40:11 - DSC TCP: Polling DSC [dsc1]
2019-11-15 13:40:11 - DSC: 50000025[C][L] [dsc1]
2019-11-15 13:40:11 - DSC: 500 - Command Acknowledge (000) [dsc1]
2019-11-15 13:41:11 - DSC TCP: Polling DSC [dsc1]
2019-11-15 13:41:11 - DSC: 50000025[C][L] [dsc1]
2019-11-15 13:41:11 - DSC: 500 - Command Acknowledge (000) [dsc1]
2019-11-15 13:42:11 - DSC TCP: Polling DSC [dsc1]
2019-11-15 13:42:11 - DSC: 50000025[C][L] [dsc1]
2019-11-15 13:42:11 - DSC: 500 - Command Acknowledge (000) [dsc1]
2019-11-15 13:43:04 - DSC: 6100042B[C][L] [dsc1]
2019-11-15 13:43:04 - DSC: 610 - Zone Restored (Zone 004) [dsc1]
2019-11-15 13:43:04 - DSC: Zone 4 (Door Cadiz)  Closed [dsc1]
2019-11-15 13:43:04 - DSC: 6502CD[C][L] [dsc1]
2019-11-15 13:43:04 - DSC: 650 - Partition Ready (Partition 2) [dsc1]
2019-11-15 13:43:04 - DSC: System Status - Ready (Partition 2) [dsc1]
2019-11-15 13:43:11 - DSC TCP: Polling DSC [dsc1]
2019-11-15 13:43:11 - DSC: 50000025[C][L] [dsc1]
2019-11-15 13:43:11 - DSC: 500 - Command Acknowledge (000) [dsc1]
2019-11-15 13:44:11 - DSC TCP: Polling DSC [dsc1]
2019-11-15 13:44:11 - DSC: 50000025[C][L] [dsc1]
2019-11-15 13:44:11 - DSC: 500 - Command Acknowledge (000) [dsc1]
2019-11-15 13:45:11 - DSC TCP: Polling DSC [dsc1]
2019-11-15 13:45:11 - DSC: 50000025[C][L] [dsc1]
2019-11-15 13:45:11 - DSC: 500 - Command Acknowledge (000) [dsc1]
2019-11-15 13:46:11 - DSC TCP: Polling DSC [dsc1]
2019-11-15 13:46:11 - DSC: 50000025[C][L] [dsc1]
2019-11-15 13:46:11 - DSC: 500 - Command Acknowledge (000) [dsc1]
2019-11-15 13:47:11 - DSC TCP: Polling DSC [dsc1]
2019-11-15 13:47:11 - DSC: 50000025[C][L] [dsc1]
2019-11-15 13:47:11 - DSC: 500 - Command Acknowledge (000) [dsc1]
2019-11-15 13:48:11 - DSC TCP: Polling DSC [dsc1]
2019-11-15 13:48:11 - DSC: 50000025[C][L] [dsc1]
2019-11-15 13:48:11 - DSC: 500 - Command Acknowledge (000) [dsc1]
2019-11-15 13:49:11 - DSC TCP: Polling DSC [dsc1]
2019-11-15 13:49:11 - DSC: 50000025[C][L] [dsc1]
2019-11-15 13:49:11 - DSC: 500 - Command Acknowledge (000) [dsc1]
2019-11-15 13:50:11 - DSC TCP: Polling DSC [dsc1]
2019-11-15 13:50:11 - DSC: 50000025[C][L] [dsc1]
2019-11-15 13:50:11 - DSC: 500 - Command Acknowledge (000) [dsc1]
2019-11-15 13:51:11 - DSC TCP: Polling DSC [dsc1]
2019-11-15 13:51:11 - DSC: 50000025[C][L] [dsc1]
2019-11-15 13:51:11 - DSC: 500 - Command Acknowledge (000) [dsc1]
2019-11-15 13:52:11 - DSC TCP: Polling DSC [dsc1]
2019-11-15 13:52:11 - DSC: 50000025[C][L] [dsc1]
2019-11-15 13:52:11 - DSC: 500 - Command Acknowledge (000) [dsc1]
2019-11-15 13:53:11 - DSC TCP: Polling DSC [dsc1]
2019-11-15 13:53:11 - DSC: 50000025[C][L] [dsc1]
2019-11-15 13:53:11 - DSC: 500 - Command Acknowledge (000) [dsc1]
2019-11-15 13:54:11 - DSC TCP: Polling DSC [dsc1]
2019-11-15 13:54:11 - DSC: 50000025[C][L] [dsc1]
2019-11-15 13:54:11 - DSC: 500 - Command Acknowledge (000) [dsc1]
2019-11-15 13:55:11 - DSC TCP: Polling DSC [dsc1]
2019-11-15 13:55:11 - DSC: 50000025[C][L] [dsc1]
2019-11-15 13:55:11 - DSC: 500 - Command Acknowledge (000) [dsc1]
2019-11-15 13:56:11 - DSC TCP: Polling DSC [dsc1]
2019-11-15 13:56:11 - DSC: 50000025[C][L] [dsc1]
2019-11-15 13:56:11 - DSC: 500 - Command Acknowledge (000) [dsc1]
2019-11-15 13:56:33 - DSC: 51080FE[C][L] [dsc1]
2019-11-15 13:56:33 - DSC: 510 - Full LED Status Update [dsc1]
2019-11-15 13:56:35 - DSC: 51120F9[C][L] [dsc1]
2019-11-15 13:56:35 - DSC: 511 - Full LED Status (Flash) Update [dsc1]
2019-11-15 13:56:35 - DSC: 6801CF[C][L] [dsc1]
2019-11-15 13:56:35 - DSC: 680 -  [dsc1]
2019-11-15 13:56:35 - DSC: 5108200[C][L] [dsc1]
2019-11-15 13:56:35 - DSC: 510 - Full LED Status Update [dsc1]
2019-11-15 13:56:36 - DSC: 6732D2[C][L] [dsc1]
2019-11-15 13:56:36 - DSC: 673 - Partition Busy (Partition 2) [dsc1]
2019-11-15 13:56:40 - DSC: 6801CF[C][L] [dsc1]
2019-11-15 13:56:40 - DSC: 680 -  [dsc1]
2019-11-15 13:56:40 - DSC: 51081FF[C][L] [dsc1]
2019-11-15 13:56:40 - DSC: 510 - Full LED Status Update [dsc1]
2019-11-15 13:56:50 - DSC: 6801CF[C][L] [dsc1]
2019-11-15 13:56:50 - DSC: 680 -  [dsc1]
2019-11-15 13:56:50 - DSC: 5108200[C][L] [dsc1]
2019-11-15 13:56:50 - DSC: 510 - Full LED Status Update [dsc1]
2019-11-15 13:56:51 - DSC: 51081FF[C][L] [dsc1]
2019-11-15 13:56:51 - DSC: 510 - Full LED Status Update [dsc1]
2019-11-15 13:56:51 - DSC: 6531CF[C][L]6502CD[C][L] [dsc1]
2019-11-15 13:56:51 - DSC: 653 - Partition in Ready to Force Arm (Partition 1) [dsc1]
2019-11-15 13:56:51 - DSC: 650 - Partition Ready (Partition 2) [dsc1]
2019-11-15 13:56:51 - DSC: System Status - Ready (Partition 2) [dsc1]
2019-11-15 13:56:52 - DSC: 51100F7[C][L] [dsc1]
2019-11-15 13:56:52 - DSC: 511 - Full LED Status (Flash) Update [dsc1]
2019-11-15 13:56:53 - DSC: 51080FE[C][L] [dsc1]
2019-11-15 13:56:53 - DSC: 510 - Full LED Status Update [dsc1]
2019-11-15 13:56:54 - DSC: 51081FF[C][L] [dsc1]
2019-11-15 13:56:54 - DSC: 510 - Full LED Status Update [dsc1]
2019-11-15 13:56:55 - DSC: 91212FF[C][L] [dsc1]
2019-11-15 13:56:55 - DSC: 912 - Command Output Pressed (Partition 1, Output 2) [dsc1]
2019-11-15 13:56:55 - DSC: Command Output 2 Triggered [dsc1]
2019-11-15 13:56:55 - DSC: 6601CD[C][L] [dsc1]
2019-11-15 13:56:55 - DSC: 660 - Command Output in Progress (Partition 1) [dsc1]
2019-11-15 13:57:00 - DSC: 6531CF[C][L] [dsc1]
2019-11-15 13:57:00 - DSC: 653 - Partition in Ready to Force Arm (Partition 1) [dsc1]
2019-11-15 13:57:11 - DSC TCP: Polling DSC [dsc1]
2019-11-15 13:57:11 - DSC: 50000025[C][L] [dsc1]
2019-11-15 13:57:11 - DSC: 500 - Command Acknowledge (000) [dsc1]
2019-11-15 13:57:16 - DSC: 51080FE[C][L] [dsc1]
2019-11-15 13:57:16 - DSC: 510 - Full LED Status Update [dsc1]
2019-11-15 13:57:16 - DSC: 51081FF[C][L] [dsc1]
2019-11-15 13:57:17 - DSC: 91212FF[C][L] [dsc1]
2019-11-15 13:57:17 - DSC: 912 - Command Output Pressed (Partition 1, Output 2) [dsc1]
2019-11-15 13:57:17 - DSC: Command Output 2 Triggered [dsc1]
2019-11-15 13:57:17 - DSC: 6601CD[C][L] [dsc1]
2019-11-15 13:57:17 - DSC: 660 - Command Output in Progress (Partition 1) [dsc1]
2019-11-15 13:57:22 - DSC: 6531CF[C][L] [dsc1]
2019-11-15 13:57:22 - DSC: 653 - Partition in Ready to Force Arm (Partition 1) [dsc1]
2019-11-15 13:57:26 - DSC: 51080FE[C][L] [dsc1]
2019-11-15 13:57:26 - DSC: 510 - Full LED Status Update [dsc1]
2019-11-15 13:57:27 - DSC: 51081FF[C][L] [dsc1]
2019-11-15 13:57:27 - DSC: 510 - Full LED Status Update [dsc1]
2019-11-15 13:57:27 - DSC: 91212FF[C][L] [dsc1]
2019-11-15 13:57:27 - DSC: 912 - Command Output Pressed (Partition 1, Output 2) [dsc1]
2019-11-15 13:57:27 - DSC: Command Output 2 Triggered [dsc1]
2019-11-15 13:57:27 - DSC: 6601CD[C][L] [dsc1]
2019-11-15 13:57:27 - DSC: 660 - Command Output in Progress (Partition 1) [dsc1]
2019-11-15 13:57:30 - DSC: 6531CF[C][L] [dsc1]
2019-11-15 13:57:30 - DSC: 653 - Partition in Ready to Force Arm (Partition 1) [dsc1]
2019-11-15 13:58:11 - DSC TCP: Polling DSC [dsc1]
2019-11-15 13:58:11 - DSC: 50000025[C][L] [dsc1]
2019-11-15 13:58:11 - DSC: 500 - Command Acknowledge (000) [dsc1]
2019-11-15 13:58:28 - DSC: 51080FE[C][L] [dsc1]
2019-11-15 13:58:28 - DSC: 510 - Full LED Status Update [dsc1]
2019-11-15 13:58:29 - DSC: 51081FF[C][L] [dsc1]
2019-11-15 13:58:29 - DSC: 510 - Full LED Status Update [dsc1]
2019-11-15 13:58:29 - DSC: 91212FF[C][L] [dsc1]
2019-11-15 13:58:29 - DSC: 912 - Command Output Pressed (Partition 1, Output 2) [dsc1]
2019-11-15 13:58:29 - DSC: Command Output 2 Triggered [dsc1]
2019-11-15 13:58:29 - DSC: 6601CD[C][L] [dsc1]
2019-11-15 13:58:29 - DSC: 660 - Command Output in Progress (Partition 1) [dsc1]
2019-11-15 13:58:34 - DSC: 6531CF[C][L] [dsc1]
2019-11-15 13:58:34 - DSC: 653 - Partition in Ready to Force Arm (Partition 1) [dsc1]
2019-11-15 13:59:11 - DSC TCP: Polling DSC [dsc1]
2019-11-15 13:59:11 - DSC: 50000025[C][L] [dsc1]
2019-11-15 13:59:11 - DSC: 500 - Command Acknowledge (000) [dsc1]
2019-11-15 13:59:48 - DSC: 51080FE[C][L] [dsc1]
2019-11-15 13:59:48 - DSC: 510 - Full LED Status Update [dsc1]
2019-11-15 13:59:49 - DSC: 51081FF[C][L] [dsc1]
2019-11-15 13:59:49 - DSC: 510 - Full LED Status Update [dsc1]
2019-11-15 13:59:49 - DSC: 91212FF[C][L] [dsc1]
2019-11-15 13:59:49 - DSC: 912 - Command Output Pressed (Partition 1, Output 2) [dsc1]
2019-11-15 13:59:49 - DSC: Command Output 2 Triggered [dsc1]
2019-11-15 13:59:49 - DSC: 6601CD[C][L] [dsc1]
2019-11-15 13:59:49 - DSC: 660 - Command Output in Progress (Partition 1) [dsc1]
2019-11-15 13:59:54 - DSC: 6531CF[C][L] [dsc1]
2019-11-15 13:59:54 - DSC: 653 - Partition in Ready to Force Arm (Partition 1) [dsc1]
2019-11-15 14:00:09 - DSC: 60900332[C][L] [dsc1]
2019-11-15 14:00:09 - DSC: 609 - Zone Open (Zone 003) [dsc1]
2019-11-15 14:00:09 - DSC: Zone 3 (Door Front)  Opened [dsc1]
2019-11-15 14:00:09 - DSC: 51080FE[C][L] [dsc1]
2019-11-15 14:00:09 - DSC: 510 - Full LED Status Update [dsc1]
2019-11-15 14:00:09 - DSC: 6511CD[C][L] [dsc1]
2019-11-15 14:00:09 - DSC: 651 - Partition Not Ready (Partition 1) [dsc1]
2019-11-15 14:00:09 - DSC: System Status - Not Ready (Partition 1) [dsc1]
2019-11-15 14:00:09 - DSC: System Status - Disarmed (Set By Status Request - Partition 1) [dsc1]
2019-11-15 14:00:11 - DSC TCP: Polling DSC [dsc1]
2019-11-15 14:00:11 - DSC: 50000025[C][L] [dsc1]
2019-11-15 14:00:11 - DSC: 500 - Command Acknowledge (000) [dsc1]
2019-11-15 14:00:15 - DSC: 6100032A[C][L] [dsc1]
2019-11-15 14:00:15 - DSC: 610 - Zone Restored (Zone 003) [dsc1]
2019-11-15 14:00:15 - DSC: Zone 3 (Door Front)  Closed [dsc1]
2019-11-15 14:00:15 - DSC: 51081FF[C][L] [dsc1]
2019-11-15 14:00:15 - DSC: 510 - Full LED Status Update [dsc1]
2019-11-15 14:00:15 - DSC: 6531CF[C][L] [dsc1]
2019-11-15 14:00:15 - DSC: 653 - Partition in Ready to Force Arm (Partition 1) [dsc1]
2019-11-15 14:00:36 - DSC: 60900332[C][L] [dsc1]
2019-11-15 14:00:36 - DSC: 609 - Zone Open (Zone 003) [dsc1]
2019-11-15 14:00:36 - DSC: Zone 3 (Door Front)  Opened [dsc1]
2019-11-15 14:00:36 - DSC: 51080FE[C][L] [dsc1]
2019-11-15 14:00:36 - DSC: 510 - Full LED Status Update [dsc1]
2019-11-15 14:00:36 - DSC: 6511CD[C][L] [dsc1]
2019-11-15 14:00:36 - DSC: 651 - Partition Not Ready (Partition 1) [dsc1]
2019-11-15 14:00:36 - DSC: System Status - Not Ready (Partition 1) [dsc1]
2019-11-15 14:00:41 - DSC: 6100032A[C][L] [dsc1]
2019-11-15 14:00:41 - DSC: 610 - Zone Restored (Zone 003) [dsc1]
2019-11-15 14:00:41 - DSC: Zone 3 (Door Front)  Closed [dsc1]
2019-11-15 14:00:41 - DSC: 51081FF[C][L] [dsc1]
2019-11-15 14:00:41 - DSC: 510 - Full LED Status Update [dsc1]
2019-11-15 14:00:41 - DSC: 6531CF[C][L] [dsc1]
2019-11-15 14:00:41 - DSC: 653 - Partition in Ready to Force Arm (Partition 1) [dsc1]
2019-11-15 14:01:10 - DSC: 51080FE[C][L] [dsc1]
2019-11-15 14:01:10 - DSC: 510 - Full LED Status Update [dsc1]
2019-11-15 14:01:11 - DSC TCP: Polling DSC [dsc1]
2019-11-15 14:01:11 - DSC: 51081FF[C][L] [dsc1]
2019-11-15 14:01:11 - DSC: 510 - Full LED Status Update [dsc1]
2019-11-15 14:01:11 - DSC: 50000025[C][L]91212FF[C][L]6601CD[C][L] [dsc1]
2019-11-15 14:01:11 - DSC: 500 - Command Acknowledge (000) [dsc1]
2019-11-15 14:01:11 - DSC: 912 - Command Output Pressed (Partition 1, Output 2) [dsc1]
2019-11-15 14:01:11 - DSC: Command Output 2 Triggered [dsc1]
2019-11-15 14:01:11 - DSC: 660 - Command Output in Progress (Partition 1) [dsc1]
2019-11-15 14:01:17 - DSC: 6531CF[C][L] [dsc1]
2019-11-15 14:01:17 - DSC: 653 - Partition in Ready to Force Arm (Partition 1) [dsc1]
2019-11-15 14:02:11 - DSC TCP: Polling DSC [dsc1]
2019-11-15 14:02:11 - DSC: 50000025[C][L] [dsc1]
2019-11-15 14:02:11 - DSC: 500 - Command Acknowledge (000) [dsc1]
2019-11-15 14:02:17 - DSC: 60900433[C][L] [dsc1]
2019-11-15 14:02:17 - DSC: 609 - Zone Open (Zone 004) [dsc1]
2019-11-15 14:02:17 - DSC: Zone 4 (Door Cadiz)  Opened [dsc1]
2019-11-15 14:02:17 - DSC: 6512CE[C][L] [dsc1]
2019-11-15 14:02:17 - DSC: 651 - Partition Not Ready (Partition 2) [dsc1]
2019-11-15 14:02:17 - DSC: System Status - Not Ready (Partition 2) [dsc1]
2019-11-15 14:02:22 - DSC: 6100042B[C][L] [dsc1]
2019-11-15 14:02:22 - DSC: 610 - Zone Restored (Zone 004) [dsc1]
2019-11-15 14:02:22 - DSC: Zone 4 (Door Cadiz)  Closed [dsc1]
2019-11-15 14:02:22 - DSC: 6502CD[C][L] [dsc1]
2019-11-15 14:02:22 - DSC: 650 - Partition Ready (Partition 2) [dsc1]
2019-11-15 14:02:22 - DSC: System Status - Ready (Partition 2) [dsc1]
2019-11-15 14:03:11 - DSC TCP: Polling DSC [dsc1]
2019-11-15 14:03:11 - DSC: 50000025[C][L] [dsc1]
More Log
2019-11-15 14:03:11 - DSC: 500 - Command Acknowledge (000) [dsc1]
2019-11-15 14:04:11 - DSC TCP: Polling DSC [dsc1]
2019-11-15 14:04:11 - DSC: 50000025[C][L] [dsc1]
2019-11-15 14:04:11 - DSC: 500 - Command Acknowledge (000) [dsc1]
2019-11-15 14:05:11 - DSC TCP: Polling DSC [dsc1]
2019-11-15 14:05:11 - DSC: 50000025[C][L] [dsc1]
2019-11-15 14:05:11 - DSC: 500 - Command Acknowledge (000) [dsc1]
2019-11-15 14:06:11 - DSC TCP: Polling DSC [dsc1]
2019-11-15 14:06:11 - DSC: 50000025[C][L] [dsc1]
2019-11-15 14:06:11 - DSC: 500 - Command Acknowledge (000) [dsc1]
2019-11-15 14:07:11 - DSC TCP: Polling DSC [dsc1]
2019-11-15 14:07:11 - DSC: 50000025[C][L] [dsc1]
2019-11-15 14:07:11 - DSC: 500 - Command Acknowledge (000) [dsc1]
2019-11-15 14:08:10 - DSC: 60900433[C][L] [dsc1]
2019-11-15 14:08:10 - DSC: 609 - Zone Open (Zone 004) [dsc1]
2019-11-15 14:08:10 - DSC: Zone 4 (Door Cadiz)  Opened [dsc1]
2019-11-15 14:08:11 - DSC: 6512CE[C][L] [dsc1]
2019-11-15 14:08:11 - DSC: 651 - Partition Not Ready (Partition 2) [dsc1]
2019-11-15 14:08:11 - DSC: System Status - Not Ready (Partition 2) [dsc1]
2019-11-15 14:08:11 - DSC TCP: Polling DSC [dsc1]
2019-11-15 14:08:11 - DSC: 50000025[C][L] [dsc1]
2019-11-15 14:08:11 - DSC: 500 - Command Acknowledge (000) [dsc1]
2019-11-15 14:09:11 - DSC TCP: Polling DSC [dsc1]
2019-11-15 14:09:11 - DSC: 50000025[C][L] [dsc1]
2019-11-15 14:09:11 - DSC: 500 - Command Acknowledge (000) [dsc1]
2019-11-15 14:10:11 - DSC TCP: Polling DSC [dsc1]
2019-11-15 14:10:11 - DSC: 50000025[C][L] [dsc1]
2019-11-15 14:10:11 - DSC: 500 - Command Acknowledge (000) [dsc1]
2019-11-15 14:11:11 - DSC TCP: Polling DSC [dsc1]
2019-11-15 14:11:11 - DSC: 50000025[C][L] [dsc1]
2019-11-15 14:11:11 - DSC: 500 - Command Acknowledge (000) [dsc1]
2019-11-15 14:12:11 - DSC TCP: Polling DSC [dsc1]
2019-11-15 14:12:11 - DSC: 50000025[C][L] [dsc1]
2019-11-15 14:12:11 - DSC: 500 - Command Acknowledge (000) [dsc1]
2019-11-15 14:13:11 - DSC TCP: Polling DSC [dsc1]
2019-11-15 14:13:11 - DSC: 50000025[C][L] [dsc1]
2019-11-15 14:13:11 - DSC: 500 - Command Acknowledge (000) [dsc1]
2019-11-15 14:14:11 - DSC TCP: Polling DSC [dsc1]
2019-11-15 14:14:11 - DSC: 50000025[C][L] [dsc1]
2019-11-15 14:14:11 - DSC: 500 - Command Acknowledge (000) [dsc1]
2019-11-15 14:15:11 - DSC TCP: Polling DSC [dsc1]
2019-11-15 14:15:11 - DSC: 50000025[C][L] [dsc1]
2019-11-15 14:15:11 - DSC: 500 - Command Acknowledge (000) [dsc1]
2019-11-15 14:16:11 - DSC TCP: Polling DSC [dsc1]
2019-11-15 14:16:11 - DSC: 50000025[C][L] [dsc1]
2019-11-15 14:16:11 - DSC: 500 - Command Acknowledge (000) [dsc1]
2019-11-15 14:17:11 - DSC TCP: Polling DSC [dsc1]
2019-11-15 14:17:11 - DSC: 50000025[C][L] [dsc1]
2019-11-15 14:17:11 - DSC: 500 - Command Acknowledge (000) [dsc1]
2019-11-15 14:18:11 - DSC TCP: Polling DSC [dsc1]
2019-11-15 14:18:11 - DSC: 50000025[C][L] [dsc1]
2019-11-15 14:18:11 - DSC: 500 - Command Acknowledge (000) [dsc1]
Edited by apostolakisl
