Local Web Interface Credentials
Is there a way to eliminate the requirement to login to the local web interface of the ISY994i (v4.7.3)? This would be for LAN access only. We don't allow any external access (no port forwarding, etc).
Welcome to the UDI forums!
The Home Automation Dashboard (HAD), which is a more sophisticated ISY web page which can be served by the ISY.  Its the optional interface presented behind the button in the default admin page and comes loaded on the ISY.
There is a transparent proxy feature that logs in with no account and password,  if you host on your own server - which makes sense if you're local. Check the wiki here
You can customize the page for your own purposes. I made a version of it for presenting HVAC runtime info a few years ago and still use it from time to time. You can even get the pages from the internet, through the ISY portal if you host them on the ISY.
Paul
Edited by paulbates
