Is there a way to check on months without year
Hi
Is there a simple way to check on a range of dates/months without specifying the year
Say From Nov 20th to Jan 1st (every year) enable Xmas lights or similar
I can probably do this through a node server, but it would seem natural to do this using a built in option
The ISY has system values for “day of month”, “month”, “year” and so on, but these system values cannot be used in program conditions directly: the values need to be stored in program variables first. Then these variables can be used for programs and folders in conditions for partial dates, e.g., “if day-month is 16-12 then …”, which is supposed to run the program’s then block yearly on December 16th.
A program runs daily at midnight which sets these integer variables to the numbers of today’s date:
·        Date_day_of_month
·        Date_month
·        Date_year
Before the integer variables are set, the program sets the state variable “$sDate_valid” to 0, which indicates invalid date variable values during the date change. Once the date variables are all set, the state variable is set to 1, which indicates that the date variables are valid.
Program and folder conditions can be constructed by combining the state variable “$sDate_valid” with the date variables.
Program: Set day month year [Run At Startup]
        Time is 12:00:00AM
        $sDate_valid  = 0
        $Date_day_of_month  = [Current Day of Month]
        $Date_month  = [Current Month (Jan=1, Feb=2, etc.)]
        $Date_year  = [Current Year ]
        $Date_day_of_month Init To $Date_day_of_month
        $Date_month Init To $Date_month
        $Date_year Init To $Date_year
        Wait  1 second
        $sDate_valid  = 1
At midnight every day, sets the variables for the date.
Indicates that a date change was completed and that the
date variable values are again valid. Also sets the
variable init values, so that the correct date values
are restored in case of a reboot.
Example: Folder Conditions for 'Christmas time'
        $sDate_valid is 1
    And (
                  $Date_month is 11
              And $Date_day_of_month >= 21
          Or $Date_month is 12
          Or (
                  $Date_month is 1
              And $Date_day_of_month <= 15
Allows the programs in this folder to run from
November 21 through January 15 every year.
 Happy holidays!
Edited by jfailenschmid
Corrected folder condition
The logic may not be 100% correct but I get the idea and can work from this
Are the system variable documents anywhere?
1 hour ago, Panda88 said:
1) Create variables for whatever you want.  Like month, year, week, etc.
2) Create a program that runs at midnight
3) In the then section, specify that each of your variables gets set from the corresponding system value (you have to click the little black triangle to switch between different menus of items for your variables)
