Movie Scence with Status
I have created a movie scene with one button on a 6 button keypadlinc. When I press the button on the keypad the scene works as expected however the backlight on the button lights when pressed and turns off after the scene lighting completes.  I would like to keep the button lit.    I have created a scene status that should light the button via a program but it does not work.
Any suggestions?
I am using version: 5.0.16
Moshe
Michel -
Thanks for replying.  All buttons are in toggle mode.  Any other ideas.  I think it might be a program but unable to pinpoint.
There is a "find and replace" option in the program listing.  Right-click on "my programs" then go through the dialog boxes to identify the keypad button in question.  From there, it should identify any program that includes that button.  Optionally, check the program summary list immediately after controlling the scene.  If a program ran, you should be able to identify it as being the one last run at the time you pressed the button.
Edited by oberkc
Find and replace did the trick.
Thank you
MOshe
