clangren Posted December 15, 2019 Share Posted December 15, 2019 I have installed Polyglot 2.2.3 (uneventfully) on a Pi and it seems to communicate with my ISY (5.0.16A) to add the Camera NodeServer. In the ISY it never shows a menu item for the NodeServer. I have restarted both the Pi and the ISY but with no apparent effect. Got to the same point with an install on Debian Buster X64 as well. I'm probably missing something obvious but have been unable to determine the problem. Any input would be most appreciated. Debug.log attached. Thanks! debug.log Link to comment Share on other sites More sharing options...
Bumbershoot Posted December 15, 2019 Share Posted December 15, 2019 1 hour ago, clangren said: I have installed Polyglot 2.2.3 (uneventfully) on a Pi and it seems to communicate with my ISY (5.0.16A) to add the Camera NodeServer. In the ISY it never shows a menu item for the NodeServer. I have restarted both the Pi and the ISY but with no apparent effect. Got to the same point with an install on Debian Buster X64 as well. I'm probably missing something obvious but have been unable to determine the problem. Any input would be most appreciated. Debug.log attached. Thanks! debug.log 28 kB · 0 downloads After you hit the "Install" button from the Nodeserver Store, you need to go back to the "NodeServers | Add NodeServer" menu in Polyglot ("Register New NodeServer") and pick the nodeserver and ISY slot you want to install it to. Link to comment Share on other sites More sharing options...
