What Do I need to Do Next
Attached is am image of my Polisy dashboard. The node servers are there but they are all unmanaged. What do I do next?
Thanks!!
Just a guess, but did you shut down your Polyglot instance on your RPi?  Did you restore your Polyglot backup from your RPi onto your Polisy?
I disconnected the Rpi. It sounds like i need to do more than that. What did I not do that I need to do? I did restore my Polyglot backup from my RPi onto my Polisy .
Edited by dbuss
Hard to know, but I'd restart Polyglot on my Polisy first, and my ISY second.  I don't know how this works, but it appears that the Polisy Polyglot instance sees the nodeservers as being run from elsewhere.
I had the same, but as per your suggestion, I uploaded the backup from my RPi and then  all the nodeservers worked perfectly. The only thing I needed to do was to again authenticate the Google Holiday Nodeserver.
