Program to lock Yale lock and confirm that it's locked.
Hoping someone may be able to give me a quick example of how to "fancy up" a simple program.
I have a very basic program written to lock a Yale lock, I trigger this program using one of my keypadlinc buttons.
I'd kind of like to spruce up the program to give me a little more peace of mind but not quite sure how to start.
Ultimately I'd like to have it...
  • lock the lock
  • check the status to see if it's locked
  • if it's not locked try again a couple of times checking the status after each try
  • if it still is not showing locked send a notification to warn me whether its just not showing as locked for some reason, not responding or jammed... or low battery if thats possible.
I use a program to monitor the lock status. Whenever the status changes, an email is sent. No guessing and I always know the status of the lock.
I would want to experiment around here, but I wonder if there is a place for a query action?  An early conceptual approach could be something like:
if
button is pressed
then
llock door
wait a couple of seconds
query door
run check program
check program (disabled)
if
Door is unlocked
then
send notification
DennisC, there is definitely a place for the type of monitoring you are talking about but I find that too many notifications can get you acclimatized or overloaded to the point where you just don't see/hear them any longer.
Open the door to check the mail "door is unlocked" "door is locked", take out the trash "door is unlocked" "door is locked".  Because of my work I already get way more than my share of notifications from monitored equipment so it's kind of a matter of "don't tell me when something goes right... just tell me when it goes wrong".
If I'm really curious for some particular reason I can always double check the status but otherwise I'm happy for ISY to do the checking for me with the knowledge that it'll let me know when there's something I need to know (ie. ISY tried to lock the door 3 times and it's still unlocked... check this out).
There's nothing right or wrong about one method or the other, just a matter of preference.
Oberkc that's kind of what I was thinking, but with a loop of some sort around the locking/checking (and I suppose when it comes right down to it the status check could come first, if the door is already locked we don't need to lock it).  I'm just not sure how to do the loop I want in ISY-speak.
so essentially to "flowchart" it...
:start
is door locked  --> yes, end program
                           --> no    -->  have we tried to lock it 3 times yet    -->  no, lock it then go back to start to check again
        --> yes, send a notification saying something's wrong
:end program
This would probably require some type of variaable.  Without thinking too hard (it is a Sunday afterall) and without worrying too much about exact syntax, perhaps this could provide a useful starting point for you:
if
button is pressed
then
lock door
wait a little bit
query lock
run check program
if
door is unlocked
and variable is less than some number
then
query lock
increment variable
Run this program again (if path)
else
run notification program
notification program (disabled)
if
door is unlocked
then
reset variable
send message
else
Reset variable
