Another Triggerlinc Question...Controller?
Hi,
I set a new scene called Garage Light. I wanted to make the basement triggerlinc the controller & the Garage Light the responder. I tried to do that in the ISY by putting hte triggerlinc into linking mode, then creating the scene & trying to add the triggerlinc as the controller (it wasnt a clickable option).
I then decided to do it manually (by holding the garage light set button). It now works & I cant get over how fast the response time is.
My question is, how can I make the ISY see this new scene that i created outside of the ISY?
Rich
Hi Rich -
What ISY firmware version are you running?
You would be better off deleting the manually created link and recreating the scene using the ISY. You should be able to right-click the TriggerLinc and choose "Add To Scene".
What issue were you having?
Mike,
I am using firmware 2.76.
My issue was it was not giving me an option of the Triggerlinc being the controller, only the responder (which was strange).
It all works as expected though.
Rich
Hi Rich -
You may want to remove that TriggerLinc and re-add it to your ISY. I just tested to be sure, and I'm able to add a TriggerLinc as a controller to a scene with firmware 2.7.6.
It should not prompt you at all, it should simply add it to the scene as a controller.
Mike,
It does work as you said it would.
Out of curiousity, if I already have a scene & I want to add a controller to a device that is already a responder, how can I change that device so that its a controller?
Right now, I remove & readd the device to the scene. Is there an easier way?
Rich
No, unfortunately you must remove the responder and re-add as a controller.
