Insteon 2477D two switch pressed at the same time causes blinking red light for a short while
Has anyone else noticed this, I'm not sure it's a feature or a bug.
I have a bunch of Insteon switches and a few of the locations have 6 switches.  Almost all of them are the 2477D v.45
When I click multiple at the same time, close to the same time I see the LED indicate turning off, or on depending on if I'm turning it off or on.  Then the red LED on the switch will blink for a couple of second and go out.  Is this normal?
Here is the log from the ISY-
d 02/05/2020 11:34:08 AM : [INST-SRX    ] 02 50 4F.7B.86 34.E6.20 4F 11 01    LTONRR (01)
Wed 02/05/2020 11:34:08 AM : [Std-Cleanup ] 4F.7B.86-->ISY/PLM Group=1, Max Hops=3, Hops Left=3
Wed 02/05/2020 11:34:08 AM : [D2D EVENT   ] Event [4F 7B 86 1] [DON] [0] uom=0 prec=-1
Wed 02/05/2020 11:34:08 AM : [  4F 7B 86 1]      DON   0
Wed 02/05/2020 11:34:08 AM : [D2D EVENT   ] Event [4F 7B 86 1] [ST] [255] uom=100 prec=0
Wed 02/05/2020 11:34:08 AM : [  4F 7B 86 1]       ST 255 (uom=100 prec=0)
Wed 02/05/2020 11:34:08 AM : [D2D EVENT   ] Event [4F C1 A3 1] [ST] [255] uom=100 prec=0
Wed 02/05/2020 11:34:08 AM : [  4F C1 A3 1]       ST 255 (uom=100 prec=0)
Wed 02/05/2020 11:34:10 AM : [INST-SRX    ] 02 50 4F.7B.86 11.02.01 C3 06 01           (01)
Wed 02/05/2020 11:34:10 AM : [Std-Group   ] 4F.7B.86-->11.02.01, Max Hops=3, Hops Left=0
Wed 02/05/2020 11:34:10 AM : [INST-INFO   ] Previous message ignored.
Wed 02/05/2020 11:34:10 AM : [INST-SRX    ] 02 50 4F.C5.06 11.02.01 CF 06 01           (01)
Wed 02/05/2020 11:34:10 AM : [Std-Group   ] 4F.C5.06-->11.02.01, Max Hops=3, Hops Left=3
Most likely both are trying to send and receive messages from linked devices causing a collision somewhere so a responders message isn't getting back to them
A few things to consider as these can be a signs:
- Load: The bulb in use (CFL, LED, Florescent) may be absorbing / injecting noise on the line
- Hardware: One of the first of many signs of a failing switch are buzzing, flicker, or failure to turn on-off a load or react on a timely fashion.
- Programming: Another sign of a failing switch is it takes longer or simply won't accept new changes in the EEPROM.
