February 7, 20206 yr TRying to add a Leviton Zwave plus dimmer. I just moved and trying to integrate an existing Z-Wave device into my ISY. Since I moved, I factory reset my ISY. Purchased the Z-Wave module for my 944. I currently have ZERO devices setup. Looks like my Insteon PLM did not like moving and will not integrate with the ISY (telling me it is defective, new PLM is on order and in "safe mode" until then). However, in the meantime would like to get the ZWave devices working. Quote Elapsed 00:00:07.263 : Loading Variables Elapsed 00:00:08.237 : Loading Node Definitions Elapsed 00:00:08.739 : Loading Nodes Elapsed 00:00:08.906 : Creating Widgets Elapsed 00:00:14.034 : Creating Widgets Complete Fri 02/07/2020 10:16:52 AM : Starting Subscription Fri 02/07/2020 10:16:53 AM : Completing initialization Fri 02/07/2020 10:16:53 AM : Refreshing Status Fri 02/07/2020 10:16:53 AM : Refreshing Views Fri 02/07/2020 10:17:04 AM : Listening for Z-Wave devices to remove from the network Fri 02/07/2020 10:17:37 AM : Removing Z-Wave devices stopped Fri 02/07/2020 10:17:55 AM : Listening for Z-Wave devices to add to the network Fri 02/07/2020 10:18:09 AM : Z-Wave device detected, retrieving info 2 Fri 02/07/2020 10:18:09 AM : Z-Wave device detected, retrieving info 3 Fri 02/07/2020 10:18:10 AM : Z-Wave device detected, retrieving info 5 Fri 02/07/2020 10:18:10 AM : Adding Z-Wave devices stopped Fri 02/07/2020 10:18:11 AM : Device 5 of type 4.17.1 included into Z-Wave network Fri 02/07/2020 10:18:11 AM : [ZWAVE-ADD-NODE] Cannot add primary node for 5.0 Fri 02/07/2020 10:18:11 AM : [ZWAVE-ADD-NODE] Device 5.0 not added Fri 02/07/2020 10:18:11 AM : Add Node failed: Cannot create primary node for new device Is my module not working? 994i fw is at 5.0.16c. Thank you!
February 27, 20206 yr It may be obvious but did you exclude them first? My leviton switches always seemed to like being excluded first. After that they were re-included pretty easily and quickly. I have about 25 of them from switches, dimmers receptacles, a few 3ways and a could of plugin warts. It is a fairly close dense knit mesh though with other mfg devices as well. Maybe your ZWave dongle is bad? Have you tried other ZWave devices?
