How to programmatically control mini-remotes buttons
We like having our mini-remotes and have one in several rooms in our house.   However, any time we changed a scene related to a mini-remote, we would have to find all the mini-remotes and manually set them in update mode.  Maybe we are lazy, but having to gather my three remotes every time we made adjustments was a pain.
Instead, we created the following set of programs to control the buttons on a mini-remote.  For each button, you need to create one scene and eight programs. You never have to put the mini-remotes in update mode.
  1. Scene:  this has all the devices you want the button to control
  2. Programs:
    1. One to be used to tell if any of the devices in the scene are on or off.
    2. Seven Programs: to be used for ON, OFF, FAST ON, FAST OFF, FADE UP, FADE STOP, FADE DOWN
Is this crazy? Or is there a better way to do this?
1. Create a separate Scene for each button of the mini-remote.  I use the eight-button remote and have each remote do the exact same function, and then in each of the scenes add the devices that you want to control.  Here is what the scene for the "A" button looks like:
2. Next create a program for each button that is true if any light in that scene is on. This will be used in the following program to determine if the button press should turn the scene on or off.
Here is what the program for the  "A" Scene looks like:
MiniRemote-A-Any-ON
	'Family Room / Family Room KeyPad / Family Room KeyPad-Outlets' Status is not Off
Or 	'Family Room / Family Room Outlets' Status is not Off
	No Actions - (To add one, press 'Action')
3. Finally, create a separate program for each button press.  I created a program for ON, OFF, FAST ON, FAST OFF, FADE UP, FADE STOP, FADE DOWN:
872273760_ScreenShot2020-02-08at7_30_33AM.thumb.png.fbcafbf915f6b615e1946801e7c10630.png
 FadeDown
There are three remotes at our house, so I need to check if an of the three remotes have a button press:
MiniRemote-A-FadeDown
	'Mini Remotes / Mini Remote - 1 / Mini Remote-1-A' is switched Fade Down
Or 	'Mini Remotes / Mini Remote - 2 / Mini Remote-2-A' is switched Fade Down
Or 	'Mini Remotes / Mini Remote - 3 / Mini Remote-3-A' is switched Fade Down
	Repeat 2 times
	Set 'Scenes / Mini Remotes Scenes / Mini-Remote-A' Fade Down
FadeStop
MiniRemote-A-FadeStop
	'Mini Remotes / Mini Remote - 1 / Mini Remote-1-A' is switched Fade Stop
Or 	'Mini Remotes / Mini Remote - 2 / Mini Remote-2-A' is switched Fade Stop
Or 	'Mini Remotes / Mini Remote - 3 / Mini Remote-3-A' is switched Fade Stop
	Repeat 2 times
	Set 'Scenes / Mini Remotes Scenes / Mini-Remote-A' Fade Stop
 FadeUp
MiniRemote-A-FadeUp
	'Mini Remotes / Mini Remote - 1 / Mini Remote-1-A' is switched Fade Up
Or 	'Mini Remotes / Mini Remote - 2 / Mini Remote-2-A' is switched Fade Up
Or 	'Mini Remotes / Mini Remote - 3 / Mini Remote-3-A' is switched Fade Up
	Repeat 2 times
	Set 'Scenes / Mini Remotes Scenes / Mini-Remote-A' Fade Up
 FastOff
MiniRemote-A-FastOff
		 	'Mini Remotes / Mini Remote - 1 / Mini Remote-1-A' is switched Fast On
		Or 	'Mini Remotes / Mini Remote - 1 / Mini Remote-1-A' is switched Fast Off
	Or (
			'Mini Remotes / Mini Remote - 2 / Mini Remote-2-A' is switched Fast On
		Or 	'Mini Remotes / Mini Remote - 2 / Mini Remote-2-A' is switched Fast Off
	Or (
			'Mini Remotes / Mini Remote - 3 / Mini Remote-3-A' is switched Fast On
		Or  'Mini Remotes / Mini Remote - 3 / Mini Remote-3-A' is switched Fast Off
	And Program 'MiniRemote-A-Any-ON' is True
	Repeat 2 times
	Set 'Scenes / Mini Remotes Scenes / Mini-Remote-A' Fast Off
 FastOn
MiniRemote-A-FastOn
	Or (
	Or (
	And Program 'MiniRemote-A-Any-ON' is False
	Repeat 2 times
	Set 'Scenes / Mini Remotes Scenes / Mini-Remote-A' Fast On
Off
MiniRemote-A-Off
		 	'Mini Remotes / Mini Remote - 1 / Mini Remote-1-A' is switched On
		Or 	'Mini Remotes / Mini Remote - 1 / Mini Remote-1-A' is switched Off
	Or (
			'Mini Remotes / Mini Remote - 2 / Mini Remote-2-A' is switched On
		Or 	'Mini Remotes / Mini Remote - 2 / Mini Remote-2-A' is switched Off
	Or (
			'Mini Remotes / Mini Remote - 3 / Mini Remote-3-A' is switched On
		Or  'Mini Remotes / Mini Remote - 3 / Mini Remote-3-A' is switched Off
	Repeat 2 times
	Set 'Scenes / Mini Remotes Scenes / Mini-Remote-A' Off
On
MiniRemote-A-On
	Or (
	Or (
	Repeat 2 times
	Set 'Scenes / Mini Remotes Scenes / Mini-Remote-A' On
Edited by Bobby g
If you want to use each button as a toggle, I would use variables to track what was done and turn things on/off that way. With that said, as long as it works then you're good.
