force update of occupancy node server on isy restart
Hi, I've been searching around quite a bit and have not come across info on this.
I have the occupancy node server setup on the portal and its working fine.
I've noticed that whenever my ISY reboots, the nodes for occupancy are not automatically updated and I've tried using a program to query the node with "run at startup" and it doesn't seem to do anything.  It seems that the node status is NULL -- there is no value.  This is causing my programs to think that the house is unoccupied which it is not.
Any way around this?
Could it be a timing issue?  Maybe when your program runs at startup before the ISY has connected to the occupancy node server?  Have you tried putting a WAIT in your statup program before querying the node?
