2 Features - On Error and Run Program on Folder True
kevinkaz
Item 1: ON ERROR condition
I can not control the signal damaging devices my family plugs into the home outlets. These devices create comm errors. We need an ON ERROR condition so the items that I deem important could be queried and/or adjusted to my needs.
Item 2: Run Program on Folder True
Use the "Run at Startup" condition to run a program when the parent folder becomes true.
Hi kevinkaz,
Thanks so very much for the feedback.
The first one is already on our list but we have put a low priority on it mostly because it may cause some other issues including infinite loops. But, it's in our list.
I will have to get back to you on the second one.
Hello Kevinkaz,
As I promised, I am getting back to you on #2:
As a workaround, you can already accomplish this if you add folder=true as a condition to your program(s).
We may be able to add something similar to what you are proposing but overloading Run at Startup will cause us major testing, regression testing, and support calls.
