Can't remember how to do this
And I can't find the post where I originally found out about this "feature".
How does one turn off the backlight for the off button on a KPL?
Quote from SH forum by slee "One added tip if you want the off light on a keypad to never light up which is perfect for a bedroom would be to put the On / Off part of the keypad in non-toggle mode. Here is hou to do it. In the old keypads from over a year ago you would just push the off button once and then press and hold the set button fro three seconds then release and do it again for three seconds and release and then one more set of three seconds. Now push the On button and the one will light up but when you push the off it will not light up. In the newer keypads you will have to do this proceedure twice meaning the first time you do the 3,3,and 3 second step it will only put the keypad in non-toggle Off you will need to do the 3,3 and three one more time to put the keypad in non-toggle ON."
Tim
I knew I read that somewhere. Thanks guys.
