March 29, 20206 yr I am a long time ISY and Insteon user. However, I just completed a renovation and now have z-wave 200+ Dimmer switches throughout my home and I am now setting up a new ISY with zwave. I am new to z-wave. I added a homeseer dimmer switch to the ISY (through "add/include a Z-wave device" then tapped the paddle on the switch), it added itself seamlessly, but I don't see how I set on levels, ramp rates, etc. The only options I see are the ability to turn the switch on/off or dim up/down. Are my z-wave Homeseer 200+ switches being added to ISY correctly? Can ISY control these options? See screenshot that shows the options I am provided with.
March 29, 20206 yr 27 minutes ago, jwagner010 said: I am a long time ISY and Insteon user. However, I just completed a renovation and now have z-wave 200+ Dimmer switches throughout my home and I am now setting up a new ISY with zwave. I am new to z-wave. I added a homeseer dimmer switch to the ISY (through "add/include a Z-wave device" then tapped the paddle on the switch), it added itself seamlessly, but I don't see how I set on levels, ramp rates, etc. The only options I see are the ability to turn the switch on/off or dim up/down. Are my z-wave Homeseer 200+ switches being added to ISY correctly? Can ISY control these options? See screenshot that shows the options I am provided with. Yes you can, but you need to set parameters. You can set them in programs, or right click on the device, and select "Z-Wave | Set Configuration Parameter". You'll need a copy of the manual for reference.
March 29, 20206 yr Author Thanks the manual only lists the following parameters. Not sure how I set on levels and ramp rates with the ISY? Anyone have ideas or success with the Homeseer 200+ switches?
March 29, 20206 yr Right now I don't have time to look for it, but I remember very well that some time ago someone in the ISY forum gave me all the details. Using those instructions, my HS200 shows if lights in specific rooms are ON or OFF. Do a search in this forum and you should be able to find the how-to.
March 29, 20206 yr 16 minutes ago, asbril said: Right now I don't have time to look for it, but I remember very well that some time ago someone in the ISY forum gave me all the details. Using those instructions, my HS200 shows if lights in specific rooms are ON or OFF. Do a search in this forum and you should be able to find the how-to. This might be what you're referring to.
March 29, 20206 yr Author Thank you, not sure what manual version I was looking at. Appreciate the quick responses here. Let me play around and read a little more (take my mind off other things). Appreciate the help. I hope everyone is well and healthy in this difficult time. Best to everyone and their families.
March 30, 20206 yr 3 hours ago, Bumbershoot said: This might be what you're referring to. Thanks Bumbershoot, I thought that it was you, but just was not sure ?
