Posted October 25, 200718 yr Been reading the example codes and had a thought Rather than using the "ALL OFF" scene you guys helped me with, would this work? IF KPL H is ON AND SWITCH 1 IS ON OR SWITCH 2 IS ON OR SWITCH 3 IS ON.... Continuing through all 35 switches, THEN INSTEON SWITCH 1 OFF INSTEON SWITCH 2 OFF INSTEON SWITCH 3 OFF Continuing through all 35 switches and ApplianceLinks. etc. I like the idea that if anyone or anything turned a switch on, it would immediately go out, rather than waiting for the next hourly trigger to turn them all off. Would this work or any other ideas. aLf
October 25, 200718 yr This will work fine, although I would suggest using a scene to turn off all the lights in the 'Then'.
November 4, 200717 yr I like the idea that if anyone or anything turned a switch on, it would immediately go out, rather than waiting for the next hourly trigger to turn them all off. aLf Out of curiousity... what would you use this for? Keeping kids in bed after bed time?
November 4, 200717 yr It is better to use the 'is not Off' because nothing falls thru then. This code was not tested so I don't know how it behaves. If Status 'Dining Hutch' is not Off Or Status 'Family Desk' is not Off Or Status 'Family Main (load)' is not Off Or Status 'Family Screen' is not Off Or Status 'Guest Bath Main' is not Off Or Status 'Guest Bath Tub' is not Off Or Status 'Kitchen Island' is not Off Or Status 'Kitchen Main' is not Off Or Status 'Kitchen Main (slave)' is not Off Or Status 'Kitchen Pantry' is not Off Or Status 'Kitchen Sink' is not Off Or Status 'Master Bath Main' is not Off Or Status 'Master Bath Tub' is not Off Or Status 'Master Hallway' is not Off Or Status 'Master Main (load)' is not Off Or Status 'Master Main (slave)' is not Off Or Status 'Master Read Amy' is not Off Or Status 'Master Read Mark' is not Off Or Status 'Master Screen' is not Off Then Insteon 'Dining Hutch' On Insteon 'Family Desk' On Insteon 'Family Main (load)' On Insteon 'Family Screen' On Insteon 'Guest Bath Main' On Insteon 'Guest Bath Tub' On Insteon 'Kitchen Island' On Insteon 'Kitchen Main' On Insteon 'Kitchen Main (slave)' On Insteon 'Kitchen Pantry' On Insteon 'Kitchen Sink' On Insteon 'Master Bath Main' On Insteon 'Master Bath Tub' On Insteon 'Master Hallway' On Insteon 'Master Main (load)' On Insteon 'Master Main (slave)' On Insteon 'Master Read Amy' On Insteon 'Master Read Mark' On Insteon 'Master Screen' On Else Insteon 'Dining Hutch' Off Insteon 'Family Desk' Off Insteon 'Family Main (load)' Off Insteon 'Family Screen' Off Insteon 'Guest Bath Main' Off Insteon 'Guest Bath Tub' Off Insteon 'Kitchen Island' Off Insteon 'Kitchen Main' Off Insteon 'Kitchen Main (slave)' Off Insteon 'Kitchen Pantry' Off Insteon 'Kitchen Sink' Off Insteon 'Master Bath Main' Off Insteon 'Master Bath Tub' Off Insteon 'Master Hallway' Off Insteon 'Master Main (load)' Off Insteon 'Master Main (slave)' Off Insteon 'Master Read Amy' Off Insteon 'Master Read Mark' Off Insteon 'Master Screen' Off
