Endless Loop in program
Hi
I'm trying to use my harmony remote to toggle on and off a scene for watching TV... here's the script. I don't know what's going wrong, but the "Toggle Watch TV" program is stuck looping over and over again and the lights turn on and off, until I disable the script...
Any thoughts?
(name:Watch_TV)
IR 'IR_001' is Released
Run Program 'Toggle Watch TV' (If)
(name:Toggle Watch TV)
Status 'TV Light' is Off
Set Scene 'Button B -Watch TV' On
Set Scene 'Button B -Watch TV' Off
How about something like this instead:
WATCH TV ON
       IR 'IR_001' is Pressed
   And Status  'TV Light' is Off
       Set Scene 'Button B - Watch TV' On
WATCH TV OFF
   And Status  'TV Light' is On
       Set Scene 'Button B - Watch TV' Off
Hello ketchup,
In your original programs, simply clear the Enabled checkbox for the Toggle Watch TV program, so that it only runs when called from another program. This should prevent the oscillation.
However, Mike's approach will actually be a tab bit faster, since it doesn't have one program calling another program, which adds some latency. Whether the difference would be noticeable, would need to be tested.
In Mike's Watch TV Off program, I would change the line:
to:
   And Status  'TV Light' is Not Off
in case the light happened to be between 99% and 1% (not On, and not Off).
thanks for the replies
coming from a programming background, it feels a bit constrained with the fixed format of the IF Loops, but it seems to work fine now. I'm using Mike's version with two if loops, one button though...
press once = on
hold = off
I'm really starting to like the IR option and I'm really glad to have bought it.
Good point Darrell! Usually I'm pretty good about using "Nof OFFs", but I copied from a program I was using to control a relay.
