ISY Portal maintenance - 04-12-2020
40 minutes ago, Michel Kohanim said:
@JSylvia007,
I am so very sorry to hear. I think this is due to DNS propagation delays. Can you please reboot one more time and then send your error log to support@universal-devices.com?
So I've been rebooting my ISY remotely (via an IP controlled power device) about every 10ish minutes.
Still no connectivity in the ISY portal.
This could be complete coincidence, but I'm trying to approve my device in the portal, and I'm getting "Bad Request".   No other info seems to be available.   I don't know if this is related or not, but I'm letting you know in case it is diagnostically relevant to the other ongoing issue.
Talbot
Same here. Still no joy.
@tmenear
I got the same result as you.  I hope it is linked to the titled updates and not mine... :)
Looks like I am back in business!
Alexa works, and my Polyglot heartbeats restarted!
Hi guys.
... seems to be working now... at least for me...
1 minute ago, tmenear said:
Mine just worked...
 Mine now also. I did not have to reboot again.?
Problem is now resolved.
There was a misconfiguration on one of the proxy servers. When ISYs reconnected, they were directed to the less busy proxy server... which happened to be the one with the issue.
Benoit
Benoit
I can confirm that this also fixed my issue.
