Need help with a garage program
Hello,
Ive got a simple garage door program that does the following:
Status 'GrgeRly1 GC Door' is On
And Status 'GameRm KPL A' is not On
Wait 5 minutes
Send Notification to All
Wait 5 minutes
Set 'GrgeOtpt1 GC Button' On
basically, it will shut my garage door if its open for 10 minutes, but notify me at the 5 minute mark and again at 10 minutes when it shuts.
A few times however ive found my garage still open, or had my neighbor call me to say i had forgotten to close it. I did receive my TXT msgs each of those times, but i assumed the last txt msg was the garage closing and i was covered. But apparently something was blocking my garage sensor and it would not shut.
I would like to program something that will continue to TXT me when my garage is open, that way i know something is wrong and the garage is not actually closing.
I thought that my program would continue to run over and over because the "status of GrgeRly1 GC door" would continue to be "on" so my program would run over and over, but apparently thats not the case, once the Then statement runs, it will not run again even tho the If statement is still "true".
can anyone assist me, or help me with some ideas on this.
Gregg
Sorry to jump in but since it would take another event to trigger a re-evaluation of the if statement, would adding an "run if (the name of this program)" placed at the end of the program work to re-run the program if the "if" statement was still true?
Or how about creating another program to send an email to confirm the garage door closed?
Tim
as far as hardware goes im running the following:
EZIO 4 Input/2 Output Relay Controller
Garage contacts
ISY 99i
insteon KeypadLinc Dimmer 6 Button
these are the relevant peices i use that relate to my garage door. I use the keypad link to open and shut the garage from inside the house.
Michael
The AND statement is so i can push the A on my KPL and keep the garage open all the time, (in case im working outside or something).
I would like the IF/ THEN statement to continue to run as long as the IF portion is true.
it seems that once the THEN part runs the first time, it doesnt continue to run even tho the IF portion is still true
Hi reakhavoc,
The condition is using "And" which means that if any of the conditions becomes false, then the program stops. I do not think this is what you want. Is it?
Hello Gregg,
I think you should use two separate programs:
Notify Me:
       Repeat Every  5 minutes
Close Door:
       Wait  10 minutes
Michael
