Make a button or switch control a variable timer (House Fan)
I’ve seen several posts wanting to set a timer.  Here’s a setup that will allow you to turn on and off your device normally, as well as use an adjustable timer – all from a keypad or switch.
I have a house fan that I want to set for short times or up to a few hours at bed time.
Requirement:  Minimum two devices, one to actually control the fan (ApplianceLinc) and one to be the controller.  In my case I have an 8-button KeyPadLinc (KPL) at the top of the stairs and another downstairs. Note that the ApplianceLinc controls the fan and the switch has no load connected.
User instructions:  To turn the fan on or off, simply press the button on the KPL.  On turns the fan on, Off turns the fan off.  When you double click the button from either off or on position, the value of Fan_Increment will be added to the variable Fan_Remaining_Minutes.  Each successive double click will add that many more minutes to the limit of the variable.  The LED on the KPL will blink to let you know the command has been received.
That allows up to FFFF FFFF hex or 4,294,967,295 dec minutes, or 8171 years.  Of course that would take 143,165,576 double clicks, and all that clicking would take you a very long time to do.
Variable
Initial Value
Current Value
Usage
0
0
Describes how long to stay on.
Fan_Increment
30
30
Specifies your desired increment.
Scene:
House Fan
Fan
(Responder)
Upstairs Button H
(Responder)
Downstairs Button H
(Responder)
Scene:
House Fan LEDs Only
Upstairs Button H
(Responder)
Downstairs Button H
(Responder)
Programs:
Normal On:
Control ‘Upstairs Button H’ is switched On
Or
Control ‘Downstairs Button H’ is switched On
Set Scene ‘House Fan’ On
$Fan_Remaining_Minutes = 0
No Actions
Normal Off:
Control ‘Upstairs Button H’ is switched Off
Or
Control ‘Downstairs Button H’ is switched Off
Set Scene ‘House Fan’ Off
$ Fan_Remaining_Minutes = 0
Stop program ‘Decrement’
No Actions
Increment:
Control ‘Upstairs Button H’ is switched Fast On
Or
Control ‘Upstairs Button H’ is switched Fast Off
Or
Control ‘Downstairs Button H’ is switched Fast On
Or
Control ‘Downstairs Button H’ is switched Fast Off
Set Scene ‘House Fan LEDs Only’ Off
Set Scene ‘House Fan LEDs Only’ On
$Fan_Remaining_Minutes += $Fan_Increment
Run Program ‘Decrement’ (If)
No actions
Decrement:
$Fan_Remaining_Minutes > 0
Wait 1 minute
$Fan_Remaining_Minutes -= 1
If you're using MobiLinc, you can watch the variable Fan_Remaining_Minutes change on your mobile device immediately!
Cheers, AL.
NIce!
Did you know you can right click on each program icon and select "copy to clipboard", then paste into your post? It may have been less work for you than all that html, and avoids copy over errors.
Thanks, larryllix for the suggestion. This is my first post (in several years). I was searching for a way, but at that time of night didn’t get there. I didn’t have to work for the HTML, I wrote in MsWord, where making the tables is super easy, then pasted that.
Next, I will post how to adjust this so it can have a both a delay-on as well as the delay-off..
  • 3 months later...
Hi! Thank you (BitSmith and Larryllix) for offering up some of your experience an knowledge to us newbies. I haven't used an isy994i in a long time, and the last time it was using Indigo on a macbook about 6 years ago. I have very little experience writing programs but am very familiar with Insteon devices.
I have a specific problem I'm trying to solve. If you can help me with this I would be so grateful.
Controller:  8-button KeypadLinc (7)
Responder: SwitchLinc Dimmer Switch (14)
I want to use each column of buttons on the keypads as a timer control for a single LED light, controlled by a SwitchLinc Dimmer. I set the toggle on the KeypadLincs to ON only so that each press should start a timer, as follows:
Left side of KeypadLinc 1 controls LED 1
A= 30 mins
C= 60 mins
E= 90 mins
G= 120 mins
Right side of KeypadLinc 1 controls LED 2
B= 30 mins
D= 60 mins
F= 90 mins
H= 120 mins
etc...
Any suggestions?
Thanks in advance!
