Hello all,
I am very pleased to announce that we have implemented Single Signon across all of our sites: ISY Portal, Forum, and WWW. So, you can now easily roam and navigate between them simply by logging into your ISY Portal account.
Currently, you can use either method to login. This said, with the next two months, all registration and authorization will be done through ISY Portal. So, if you have time, please consider using ISY Portal to login. This way, your accounts will be linked and you wont' have to worry about a thing when we remove the standard methods for logging.
