Can uPNP be disabled on the ISY99i pro?
I haven't found an option within the admin interface to disable uPNP from the ISY. Is it possible to do so? I do not use uPNP on my network because it's chatty waste of bandwidth that fills my firewall logs with messages (I have several subnets, some of which are firewalled from my main LAN that the ISY resides on).
I am running version 2.7.6 on an ISY99i Pro.
Rick
Hi Rick,
Unfortunately not but I think this is a good feature to add. As such, I am going to add it to our list.
The only issue is that currently that's the only way clients (such as Interface Go, iLinc, mControl, IES touch screens) can find where ISY is.
Rick
Michel,
Thanks for the reply. I did not realize how many third party products rely on UPnP. It would, however, be nice to have the ability to disable it after the ISY has been discovered. I'm assuming UPnP is only used for the initial discovery of the ISY. I'm also assuming the IP address of the ISY is then used for any further communication.
I appreciate the fact that I may be an odd case, but I transfer a lot of large files wirelessly using my laptop. So any broadcasts that I can eliminate from my wireless network will only help improve my transfer rates. Sure, I could firewall the UPnP ports from my wireless side, but to me, it's much cleaner to just disable it all together!
Thanks again!
PS - I love my ISY. It just works!
Hello rickerdo,
You are very much correct: UPnP is only used for the initial discovery. This said, however, in cases where ISY is not assigned a static IP address, it's also used to broadcast IP changes so you would not have to know exactly what IP address your ISY has.
In 2.7.7 and above (still alpha), we'll use the legacy NetBIOS over TCP to enable communicating with isy using http://isy ... but this will not work with more than one ISY on the network. Furthermore, some new computers may not have NetBIOS/TCP enabled.
In any case, disabling UPnP is something that should be included in ISY.
Michel,
Thanks again!
