Two lights in scene aren't responding
I added two additional lights to an existing scene on a KPL that turns all lights off.  The two new lights I added do not turn off when I use the KPL.  They both show action as "off" in admin console.  If I press the KPL a second time, the two lights will go off along with the two bedroom lights that are programmed to turn on when the scene is on.  Any ideas?  Thanks!
Check your links in the new devices and compare them to what ISY thinks they have. Right click on each device and select it from the pulldown menu.
Is this what you mean? Not sure what I'm supposed to be checking.
Close, but check the links of the devices. Then at the bottom you will see a "compare" button that compares the device to ISY.
Like this?
25 minutes ago, smarthome_newbie said:
Do you think I should delete the scene and add it all again?
It can't hurt and is easy enough to do in ISY. Make sure your battery devices are link enabled, one at a time.
Sounds like the "On Level" is not set to 0%/Off when the KPL is the controller.
In what mode is your KPL button? "toggle" mode?  Is the KPL button ON or OFF once pressed?  When you press this button (the first time), what happens to the other lights in the scene?  Do they turn ON or OFF?
To be clear, you press the button a second time and all lights go OFF?  Is the KPL button also OFF?  Was the KPL button ON or OFF initially (before you pressed it a second time)?
That was it.  I feel dumb.  Thanks to you and the others for the help!
Nothing dumb...we all overlook things!
Glad it's all working now.
