What is the simplest program to use ?
I was wondering if there is a windows based program that is easy to use ,and program? I presently use the ISY 99I Home Automation Controller with PLM.
I have insteon lighting products and am going to add cameras, door and window security.
Would like a program that is very easy to use and be able to make changes to.
Thanks for the help
_________________
Dodger
Hi Dodger,
You can use ELK for security and Touch Switch (http://forum.universal-devices.com/viewforum.php?f=49) for Cameras and everything else. This said, however, except for full blown applications such as mControl or Home Seer, I am not sure if there are any windows programs which you are looking for.
Thanks for the help
_________________
Dodger
