Cannot Go into Programming Mode
I have lost all Zwave nodes, likely due to power supply failure a couple months ago.  finally around to diagnosing and fixing.
I cannot add (or remove) any devices.  trying with an Aeotec Siren 5.  I have several which form the backbone of the zwave mesh in the house so schlage locks can work.  I have factory reset the siren and moved within 2 feet of the isy, for as much troubleshooting ease as anything.  cannot get to connect.  admin console is waiting but never sees anything.
So I did factory reset on zwave dongle.  I'm already committed to rebuilding the whole network as it would not restore from backup.
event viewer says factory reset is complete.  also then did firmware update, to assure I'm on the latest.  lots of address verifying and then "cannot go into programming mode" ---same error I got when trying to restore backup.
Most of my previous problems have been self imposed, and I'm more than willing to eat some humble pie this time as well.  But I'm stuck, and need help.
Ideas?
trying z wave update again.
popup says:
change of state failed:SID not found [uuid:0]
Z-wave command failed [ZWave 15 upgrade Z-Wave Firmware ]
popup says:
There are no updates available for the zwave board which is probably why it's failing
Thought about that.  But I get the same error when trying to restore from backup - cannot go into programming mode
and shouldnt there be a different error if its because of version already up to date?
I don't know what error you would get. Never attempted to update outside the initial update from years ago. I just know the only zwave board update was released 5+ years ago
24 minutes ago, breischaft said:
that's a good question.  how do I know?
When did you get your unit? Is there a blue light in the back of your isy
