ISY-991 Email Notification
bbb2008
Under the configuration tab I tried a couple of things. I've selected general mail and entered my email address.
I also enterred my smtp settings and tried the default option.
The smtp fails the tests.
Is there a good post on this subject or any advice?
Hello bbb2008,
Make sure there's at least one recipient.
If that does not work, please try the following SMTP settings:
Server: smtp.gmail.com
Port: 587
Userid: alerts@gmail.com
Password: holamola
Timeout: 3000
Use TLS: checked
If this works, then the problem is with your SMTP settings.
If not, then, in all likelihood, your ISY cannot get to the Internet. Can you synch your clock with an NTP server? This will let us know if ISY can get to the Internet.
When I put in your smtp settings I received a request failed. I manually changed the clock setting then hit sync now. The time returned back to the corrrect time.
Running the latest beta, downloaded and installed it today, hoping it would fix my non functioning notification, but it hasn't. I tried the test you suggested for BB2008 but didn't know what to fill in for the 'from' field, so I left it blank, and the test failed, however I can sync my clock w/ an NTP server.
What should I try next?
bbb2008 and Zellarman,
In this case, it would be great if you could check the logs in your router to see if SMTP traffic to port 587 is being blocked. Please note that some ISPs block known SMTP ports to force you to go through their own servers.
I changed to another address that uses smtp 25. It still times out.
The above address using smtp 25 works on webcam xp running on the same computer.
Hi bbb2008,
What's your ISY's firmware version?
Hi bbb2008,
This is very strange. Would you be kind enough to call us from 9AM to 5PM on Weekdays (818.631.0333), we'll login to your system to see what's causing the problems.
UD99 V.2.7.6
      37.5k
      375k
