How would you program if 'weather' Temperature < 'furnace' temperature then do something
I not sure how to code the above "if", I have not problem with the action
Two programs using a State variable. State variables can cause programs to trigger when they change value.
First program to sync your state variable with one of the device values.
     weather temperature < 99999
     $sVariable = weather temperature
Second program compares the two values
     furnace temperature > $sVariable
    do whatever you want here
I perfer a temperature != $variable to a less than, but it gets to the same place.  It means the variable isn't constantly stored to the same value if the temperature didn't change, so last updated time becomes meaningful for other uses.
Values of device fields and variables do not trigger programs unless they change.  The variable will never be written to (program will not run) unless the value changes anyway.
However that method may work better for a power up situation.
