NodeLink will not restart
tmorse305
Hi @io_guy, I had to restart the RPi that is running NodeLink.  Normally it restarts automatically but today it didn't. I couldn't see a recent log file that might be catching an error.  I tried re-installing it which seemed to work but on closer inspection the data logger was not logging data.  So I tried an app restart using the button within the browser interface.  Now it won't restart...
Any suggestion for troubleshooting this?
Thank you.
I see 2 errors.  It starts ok when started manually.  When I press the Restart button in the app, the error occurs as it closes, see 2nd screen shot.  The other is related to the DataLogger.  I noticed that the app hung when I tried to rotate the logging file.  So I deleted the Data Logger.  When I tried to add it back I got the second error, file access denied.  1st screen shot.
The restart within NodeLink isn't working well right now.  I need to fix it.
The log error is because your startup script runs NodeLink as root which is what your log file was created as.  Now a reg user (pi) is trying to write to it.  Run NodeLink with sudo from the cmdline and you won't see it.
      37.6k
      376.2k
