Are we permitted to install modules in polisy?
I wrote some code that uses bs4 module (beautifulsoup4) and it works in Jupiter and VSCode after bs4 was installed but I get error at the
line
from bs4 import BeautifulSoup
which indicated that the module is not present
I tried to install the module using pip
pip install beautifulsoup4
but I get error. Here is the response after trial to install
[admin@polisy ~]$ pip install bs4
Collecting bs4
  Downloading https://files.pythonhosted.org/packages/10/ed/7e8b97591f6f456174139ec089c769f89a94a1a4025fe967691de971f314/bs4-0.0.1.tar.gz
Collecting beautifulsoup4 (from bs4)
  Downloading https://files.pythonhosted.org/packages/66/25/ff030e2437265616a1e9b25ccc864e0371a0bc3adb7c5a404fd661c6f4f6/beautifulsoup4-4.9.1-py3-none-any.whl (     |ââââââââââââââââââââââââââââââââ| 122kB 878kB/s
Collecting soupsieve>1.2 (from beautifulsoup4->bs4)
  Downloading https://files.pythonhosted.org/packages/6f/8f/457f4a5390eeae1cc3aeab89deb7724c965be841ffca6cfca9197482e470/soupsieve-2.0.1-py3-none-any.whl
Installing collected packages: soupsieve, beautifulsoup4, bs4
ERROR: Could not install packages due to an EnvironmentError: [Errno 13] Permission denied: '/usr/local/lib/python3.7/site-packages/soupsieve'
Consider using the `--user` option or check the permissions.
