ISY Power LED
I noticed that the blue power led is now OFF on the front ISY panel?  Everything is working and I am ok with this.  Has there been a change here to disable the blue led?
The blue led was very bright and annoying especially at night because it lit up the whole room!
Either the led went bad or the power supply is starting to go. I cover mine with electrical tape
Well, I guess I'll wait for failure... I'm ok without the led.  I covered mine with tape as well.  Thanks for the reply.
It is powered directly by the power supply. If all the other functions are 100%. It sounds like it is no longer working.
I have a light dim on mine to reduce its brightness.
