neilgreene Posted October 8, 2009 Share Posted October 8, 2009 I have an ISY-26 which has been working fine for 1.5, maybe more. My M1G is on the network and works fine with iPhone control, web browser, etc. Network adapter enrolled on the bus and works great. I have exported my ISY xml file for Elk integration from my ISY, loaded into my lights on the Elk. I see the lights if I go into the ELK menu on a keypad, I can select a light and I can hit # to toggle on and off, but nothing works right now. Both devices are on the same network segment. Looking for recommendations on what to look at to resolve? Link to comment Share on other sites More sharing options...
Michel Kohanim Posted October 8, 2009 Share Posted October 8, 2009 Hello neilgreene, Long time no see! My first recommendation is to make sure that ELKRP is not connected. When ELKRP software is connected to ELK, then no other device can communicate with ELK. The next recommendation is to make sure you use port 2101 in the Configuration Tab. Do not use port 2601. With kind regards, Michel I have an ISY-26 which has been working fine for 1.5, maybe more.My M1G is on the network and works fine with iPhone control, web browser, etc. Network adapter enrolled on the bus and works great. I have exported my ISY xml file for Elk integration from my ISY, loaded into my lights on the Elk. I see the lights if I go into the ELK menu on a keypad, I can select a light and I can hit # to toggle on and off, but nothing works right now. Both devices are on the same network segment. Looking for recommendations on what to look at to resolve? Link to comment Share on other sites More sharing options...
neilgreene Posted October 8, 2009 Author Share Posted October 8, 2009 Hello neilgreene, Long time no see! My first recommendation is to make sure that ELKRP is not connected. When ELKRP software is connected to ELK, then no other device can communicate with ELK. The next recommendation is to make sure you use port 2101 in the Configuration Tab. Do not use port 2601. With kind regards, Michel I have an ISY-26 which has been working fine for 1.5, maybe more.My M1G is on the network and works fine with iPhone control, web browser, etc. Network adapter enrolled on the bus and works great. I have exported my ISY xml file for Elk integration from my ISY, loaded into my lights on the Elk. I see the lights if I go into the ELK menu on a keypad, I can select a light and I can hit # to toggle on and off, but nothing works right now. Both devices are on the same network segment. Looking for recommendations on what to look at to resolve? ELKRP is not connected. And I am using port 2101 (non-secure port) when setting up the Elk integration from the ISY to create the xml file. When I press the # key to toggle a device on/off, it beeps 1 almost like there is an error, changes the status on the display as if the device was communicated with and returns control. Link to comment Share on other sites More sharing options...
MikeB Posted October 8, 2009 Share Posted October 8, 2009 What firmware is running on the ISY and Elk? Link to comment Share on other sites More sharing options...
neilgreene Posted October 8, 2009 Author Share Posted October 8, 2009 What firmware is running on the ISY and Elk? Elk is running boot version 3.3.2 and Firmware version 5.1.20. ISY is running 2.7.0. Link to comment Share on other sites More sharing options...
Michel Kohanim Posted October 8, 2009 Share Posted October 8, 2009 Hello again, On the Admin Console, do you see the ELK Arm/Disarm status fields? With kind regards, Michel Link to comment Share on other sites More sharing options...
neilgreene Posted October 9, 2009 Author Share Posted October 9, 2009 Hello again, On the Admin Console, do you see the ELK Arm/Disarm status fields? With kind regards, Michel Now, I sure do not. Link to comment Share on other sites More sharing options...
neilgreene Posted October 9, 2009 Author Share Posted October 9, 2009 Hello again, On the Admin Console, do you see the ELK Arm/Disarm status fields? With kind regards, Michel I closed my browser and restarted and now I see the ARM/Disarm fields. Link to comment Share on other sites More sharing options...
neilgreene Posted October 9, 2009 Author Share Posted October 9, 2009 Hello again, On the Admin Console, do you see the ELK Arm/Disarm status fields? With kind regards, Michel I closed my browser and restarted and now I see the ARM/Disarm fields. I also moved my ELK to a different ip address and now it works. It changed it from 192.168.1.66 to 192.168.1.6. Don't know what the issue was there maybe, they are on the same lan segment and plugged into the same switch. But, it works now. Link to comment Share on other sites More sharing options...
